Should I block this off?
WeeMan
Post by WeeMan »
In the picture above it shows the nipple that the oil pipe should be on. I have now changed to premix with a different carb. Should I block this off?
Cheers
Danny
tuserv
Re: Should I block this off?
Post by tuserv »
yep be pluggin dat air leak
I recommend you not start the engine until you do. Autoparts stores sell rubber caps for the purpose. Make sure to use a clamp on it. A leak there will ruin your day.
WeeMan
Post by WeeMan »
oops I have had it runing for about 5 minutes. How much damage will I have done? I didn't rev it though.
Everytin' Irie, mon. Only da Heat do da damage. If it didnt run hard it be fine.
WeeMan
Post by WeeMan »
Blocked of using a length of pipe and a bolt with a clap at each end. Not coming of now :happy:
Just the kick start to sort (think it may be the circlip) and the trail tech to fit and I should be there. Its took ages but at least it should be right...I hope :coolcruise:
