HELP!! nb50 and nh80 carb swap
mmeadows
Post by mmeadows »
i know the bear could answer this queation licklity splickity but .........
i am swapping a aero 80 carb and intake on my scooter, however it is unclear what goes where as far as connecting hoses.
any ideas?
what are these.jpg (90.83 KiB) Viewed 8474 times
2013-05-14 11.18.19.jpg (97.66 KiB) Viewed 8474 times
Fule line.jpg (114.07 KiB) Viewed 8474 times
patthesoundguy
Re: nb50 and nh80 carb swap
Post by patthesoundguy »
I would check out the aero 80 manual it should give the hose locations. I had my carb off my 80 a month ago and I can't remember what went where. A couple of those hoses are for the bystarter. Which you can use a simple valve to make a manual setup.
This diagram should help :-)
http://www.cheapcycleparts.com/model_ye ... carburetor
patthesoundguy
Oh you will need to zip off the tab next to the silver idle air screw to be able to properly adjust it.
mmeadows
Post by mmeadows »
So i went ahead and bought the vacuum thing that is missing from the original aero80. my remaining 3 plugs and the carb go into that so it should be plug and play
now for the last piece of the puzzle .....
What uni filter should i get that will fit the aero 80 carb
and!!!!!
most importantly, What jets will i need for the main and pilot with a uni filter?
just a quick recap for jetting purposes i have ported my block and my stock 50cc cylinder. i have a leo vince pipe and want to run the nh80 carb/intakes/reeds with a uni
mmeadows
Post by mmeadows »
ill take pictures tomorrow but right now i cant get the carb. to pull gas from the fuel tank. Any ideas why?
all lines are hooked up like a stock nh80 im pretty sure.
is there any chance the 49cc in not enough for the bigger carb and intake to create a vacuum for the petcock?
mmeadows
Post by mmeadows »
so i lost my phone and wont have pictures for a while, probably a few days. But! i dont think pics would help me here very much,
don't trust an mmeadows "pretty sure" lol, i was way off. line are now hooked up correctly and stock. nh80 vacuum and bi starter parts,
i also have the throttle cable disconnected from the handle bars so i can use it while sitting down next to the carb.
my oil pump is fully open all the time.
attempt number 1
no air box, stock jets. It would start if i gave it alot of throttle but would run very rough. and low rpms. ( needless to say i almost pooped my pants with excitement hearing it run for the first time in a year with its new nh80 carb, reeds porting and leo pipe)
short intermittence
realizing i was running scary lean i decided to take a break until i could get more parts. but then, as i was working on my other scooters, i thought about how my aero80 main jets looked familiar, and remembered a set of dio jets i was sent by mistake, and wouldn't ya know.... they fit the aero80 carb :) and then to make it even sweeter, i heard a knock at the door and it was my uni filter, seriously 10 min after attempt 1)
Attempt number 2
Uni Filter, number 95 main jet, stock small jet/ idle jet. started right up but then idle kept revving up ( to high for my liking with new rings) so i killed the engine. And yes i had the throttle assembly in correct.
Attempt 3
Took the slide out to make sure everything was put back properly, and now she wont start :(
I'm going to re read the nh80 manual's carb section. anything i should look at especially close?
in regards to jets. any recommendations on the nh80 slow jets? only one is still offered from Honda (the aero125 40 jet) and its 17.99 + waiting.
I WANT TO RIDE!!!!
mmeadows
Re: HELP!! nb50 and nh80 carb swap
Post by mmeadows »
So the air screw is a factory preset and cant be adjusted. my plug is very wet. could this have anything to do with my 95 jet or uni filter?
ringLord4
Post by ringLord4 »
mmeadows wrote:So i went ahead and bought the vacuum thing that is missing from the original aero80. my remaining 3 plugs and the carb go into that so it should be plug and play
and!!!!!
I would go with an 85 jet and buy Uni 1" air filter hole plugs. They work great. You simply drill out 1" holes with a wood bit (slowly) and pop those little 1" plugs in their that have air filters on them. 3-4 should do. Works great, I have it on my 84 Spree.
Here's a link. Hope it helps!
http://item.mobileweb.ebay.com/viewitem ... 0459142024
ringLord4
Post by ringLord4 »
Not the filter... Could be jet
mmeadows
Post by mmeadows »
so i cant find it now but i remember a chart that explained during certain parts of throttle, only certain carb parts are in play.
the air filter and main jet dont really matter until 1/2 throttle onward.
isnt starting and the first 1/4 throttle only concerned with the throttle screw and air screw?
where does float level come into play?
i feel like im running out of options :(
wiki link
Get that set before tuning starts.
