1985 honda aero piston rings.
pod4444
Post by pod4444 »
i cant seem to find piston rings for my 85 aero on hondas web site.i think they might be disc.is there an early model elite that has the same engine as the aero that i could look for?I wanted to do a top end rebuild and i can get all the parts through honda except for the rings.
pod4444
Re: 1985 honda aero piston rings.
Post by pod4444 »
also i thought the engines were the same from 85 to 87 but if you look up the piston the number is different from 85 to 87.did they change the pistons in these year to year?
paulpauly7
Post by paulpauly7 »
just buy red efts bbk it can be used with the stock carb and stock exhaust
pod4444
Post by pod4444 »
do you have a link to where ican buy one of these kits.
paulpauly7
just pm red eft performance here on the board he will sort you out .He has some sort of super postal service working for him you will have it in you hot hand in no time
mmeadows
Post by mmeadows »
yes he could spend 185 on the best kit aviable
but i think he wanted to know where to buy a 20 part.
pod44444: the 85 aero engine was diffrent at the intake, so dont worry the rings will interchange. you can find those rings on aero50 from 85-87 and on elite 50 from 87-93. all those scootes use the af05e motor. you should be able to find them on a honda parts website. are you going to a dealer or website?
http://www.ebay.com/itm/Honda-Std-50cc- ... cb&vxp=mtr
or my honda dealer
http://www.beavertonmotorcycles.com/fic ... veh=131264
devenex
Post by devenex »
Rings don't interchange, I went through this after replacing the piston in my '85 Aero motor. While the piston's diameter stays the same throughout various iterations of the variated af05, the rings' thickness was varied.
If you're looking to keep it stock (and not have to premix) then make sure you get '85 Aero piston rings. I might still have the NOS set I bought, and would be happy to sell 'em to you if I can find 'em.
1986 Spree w/ '87 SE50 motor
mmeadows
Post by mmeadows »
i stand corrected
