To sell, or not to sell my 85 Aero 50, that is the question?
- MuscleForce57
- BMX
A week ago I purchased what I was told was a running 87 Honda Spree for cheap off CL. I almost made it home when the starting drive gear fell off, uh oh! I brushed it off as "what do you expect stupid for buying a cheap scooter off CL?" I figured I would paint the thing while I tried to figure out what i need to do to get it running.
I posted some pics of my super nice paint job and was informed that what I actually bought was a 85 Aero 50 by some helpful forum members.
Tonight I went over to a buddies house and with his help was able to determine that we will probably have to pull the whole engine apart to fix the problem as the starting drive gear took a hunk of the shaft it was welded to off with it.
I don't really want to take the time to part the thing out. I probably don't want to dump a bunch more into taking it to a shop for a rebuild. So that leaves either trying to take it to the welder up the street for a patch job, or just sell the thing and try to get my money back. I really like this little scoot and want to ride it, but may be in over my head.
Any suggestions?
Any suggestions?
- photo-1.JPG (135.19 KiB) Viewed 9359 times
- photo.JPG (159.32 KiB) Viewed 9359 times
- paulpauly7
Re: To sell, or not to sell my 85 Aero 50, that is the quest
it really aint that hard to rebuild it and wont cost much
- MuscleForce57
- BMX
Thanks for the vote of confidence!
pauly will tell you that most of what i say is pointless, but here are my ramblings on this issue...... your issue is you need a new/used crank.
IF you did this operation, it would be a great learning experience to pull apart the engine and put a new crank in. while the engine was apart you could replace parts that would ensure it would run for 1000's of miles and make it go faster.
If you did this operation you would also... spend $60 on a tool( tusk crank puller) and $25 on another ( flywheel puller) these are tools that you might only use once in your life
you would also need new bearings and seals ( $36.00) and im sure you would find a used crank for around $50 ( member on this forum might give you a better deal).... oh and an engine gasket set $20.00
so by this point you have now spent more money than you paid for your scooter if i rember correctly.
oh and now you still have the electric motor/ no kick start problem.
i think you should try and sell it. parting it out will take along time. i know you can sell that basket on ebay, ive seen ones where you bid, not buy, go upward of $100
if you price things to move they will sell, $15 for a seat, $5 petcock $7 coil not to mention the piston and cylinder are still good.
it shouldn't be hard to recoup your $150 just a little timely, then you can wait for a $300 honda aero with no problems thats just a little "ugly"
- MuscleForce57
- BMX
I can probably rent those tools from the nice folks at Autozoo. I think I'm going to go for it. Also Devenex recommended throwing an aftermarket variator on there while i'm all up in it. I seem to remember seeing a thread on here where to locate aftermarket parts. $100 for the basket, that's just silly! Maybe I'll sell it off just to pay for some of the parts. Also while I got the sucker all tore apart I can go through and patch all the cracks in the plastic.
If you're going to be splitting the case I would recommend opening up the intake, the intake port, and the exhaust port. Just need a dremel, some chainsaw sharpening bits and patience.
1986 Spree w/ '87 SE50 motor
- paulpauly7
sounds like a build thread is coming
- MuscleForce57
- BMX
Shornuff! Better head on over to the proper forum...
- MuscleForce57
- BMX
From WikiSpreedia Performance Tech:devenex wrote:If you're going to be splitting the case I would recommend opening up the intake, the intake port, and the exhaust port. Just need a dremel, some chainsaw sharpening bits and patience.
-Intake and Air Filter Modifications for the Spree
-Porting Exhaust - Spree
Is this what you are referring too?
promise to head over to build forum after this...paulpauly7 wrote:sounds like a build thread is coming
- MuscleForce57
- BMX
build pics
Now that this has turned into a build thread I will start posting some pics. first let's look at what went wrong. Dang ol' gear fell off my scoot while driving it home from where I bought it. Wah waaah!
- photo-4.JPG (50.51 KiB) Viewed 9316 times
- photo-5.JPG (37.62 KiB) Viewed 9316 times
- MuscleForce57
- BMX
Before photo of scoot and all taken apart to get painted. I primed it with black primer and then flat black. I did a few coats of each. It scratches off really easy so maybe i need to pull it all apart and clear-coat it? I should probably patch up the cracks too while i'm at it. For any noobs out there i recommend using painters tape to hold bolts/washers where they come out of while you paint. it makes it easier to remember where everthing goes.
- b3167a0f-822b-48e0-b827-e11406545e26_zpsc997975a.jpg (118.45 KiB) Viewed 9316 times
- 79893247-d674-47b4-9efd-2eb3ad5aae59_zps08f38b9c.jpg (65.73 KiB) Viewed 9316 times
- MuscleForce57
- BMX
getting ready to pull the motor out, clean and pull her apart. been digging around the forums for a couple hours for ideas.
- 39f18096-c31a-43cb-9390-b42eb67e5ab7_zps2dd0e42a.jpg (147.17 KiB) Viewed 9311 times
- i wonder if these black hoses need to be attached to something? Might be time to invest in a spiffy aftermarket air filter. The dirty rag it came with just ain't that stylish...
- 9d17715d-ee42-439e-881f-cdb22d875192_zpsfb267ff6.jpg (162.21 KiB) Viewed 9311 times
Kevinstonge
It looks like you have a 4 bolt intake. Which would mean you have an 86-87 aero, or at least an engine from one. I'd rebuild it as well. It has plenty of potential!!! Talk to red eft for a bore kit as well. Worth every penny.
- MuscleForce57
- BMX
Baby's first rebuild
Learning as I go. I have almost no mechanic experience. I have been receiving all my info from what I read from threads on this forum and feedback from members. Today I printed two pages from the 85 Aero 50cc Service manual (41/42) to remove my engine. Few beers later I got her out of there!
- put all my little parts in labeled bags this time to help keep track of them.
- photo-9.JPG (47.81 KiB) Viewed 9286 times
- After pulling the engine I covered the scoot with plastic to keep out dust, pollen and critters.
- photo-10.JPG (39.59 KiB) Viewed 9286 times
- MuscleForce57
- BMX
Kevinstonge wrote:It looks like you have a 4 bolt intake. Which would mean you have an 86-87 aero, or at least an engine from one. I'd rebuild it as well. It has plenty of potential!!! Talk to red eft for a bore kit as well. Worth every penny.
Thanks for the suggestion. I'm really just trying to get it back in running condition. Some of the rollers in my variator have flat spots, so i may upgrade to an aftermarket one. other than that i really only plan on cleaning it up and possibly opening up the intake and exhaust. And I need to buy crankshaft rod and starting drive gear.
