Aftermarket spree rear shock
ringLord4
Post by ringLord4 »
Anybody know if this fits the spree?
http://item.mobileweb.ebay.com/viewitem ... 0633558409
Also, looking to see if anybody has seen results from trying some Yamaha jog clutch springs on the spree. I'm looking for better take off. I'd like to find some springs. How many RPM's too??
Thanks
ringLord4
Post by ringLord4 »
Bump
devenex
Re: Aftermarket spree rear shock
Post by devenex »
I'm assuming you already know its longer and thats why you want it.
It should fit as the listed dimensions match up (10mm mounting up top w/ 8mm bolt at bottom). You might need to buy a different bolt at a hardware store for the bottom as I don't know the stock threading, but that should be the worse case scenario.
1986 Spree w/ '87 SE50 motor
ringLord4
Post by ringLord4 »
I didn't know it was longer. Haven't measured it. Is that a plus? I just don't like the stock shock. It's bouncy
devenex
Post by devenex »
Go for a used ruckus shock then, its a only a touch longer and you can scoop one up for a lot less.
ringLord4
Post by ringLord4 »
Is longer better. Will it sustain weight better?
How about clutch springs anyone have any news? Rpm?
