87 elite backroad racer
So a few weeks ago I ended up buying my first 87 elite, with a mallossi bbk and matching head, other than that she is stock.
I have been commuting and using it for rallying backroads around Oregon. I'm shooting for a reliable, yet powerful little elite. With a little ratrod/adventurous spirit added. Future mods include 24mm carb, and a leovince sp3.
As soon as I bought it I upgraded the tires to a set of Perelli sl26's, 3.00x10, and swapped the damaged turn signals out for some flush mounts.
Re: 87 elite backroad racer
Here are a few pics of her, she has a new seat on the way as the pink really isn't my style.
- image.jpg (22.2 KiB) Viewed 10615 times
- image.jpg (20.26 KiB) Viewed 10615 times
- swimmingfree
what is your top speed ???
Around 40, stock carb, stock unrestricted exhaust
- swimmingfree
just fast enough to be fun...lol
weee lol
weee lol
- martynkim
The Leo will add some more to it Shave 0.50 from the head 2K center spring Get a variator and tune it. and The rear tire should have been a 90/90/10 (would have helped)
Do you run a +2K spring? Any trouble with sheared rear pulley?
- swimmingfree
if your looking for a little more out of it i wood put in a ruckus variator 8 gram rollers and stock carb 95 jet aftermarket air filter...
- martynkim
Wheelman-111 wrote:Greetings:
No issues.
I have 8.4g rollers in there now and a ruckus variator.
I was going to go with the 2k spring, and the clutch which I have but I can't seem to get the nut off the clutch, any quick thoughts on that?
I also have a jet kit on it, with a 90 jet in there right meow.
Just finished up redoing the rearend, to Get rid of the stock looking rear and go more sleek. Tis is how she came out
- image.jpg (96.57 KiB) Viewed 10573 times
- martynkim
Adventurecrow wrote:I have 8.4g rollers in there now and a ruckus variator.
Impact, you can't beat air tools. If you don't have em invest, they will pay for themselves.
I keep having the nut on the front pulley come off while driving. I have ranked it down multiple times, then just had the thought of the washer, is there suppose to be a washer between the nut and the starting gear? It kinda goes oO()() nut, washer, big gear, variator. Should I take that washer out? I was nearly late for work due to this thing again today, had to push her a mile to make it to work on time.
So today as I was driving home from work, on a curvy backroad, one of the small bolts holding my plastics on ended up breaking the plastic and hence forth the left plastic coming off while driving, as soon as it happened I slammed the brakes and went back for it, by the time I had gotten it was all over, a Nissan pathfinder found its way over it
breakage, so I ripped the other side off threw it in the ditch and rode home, guess ill be going a little bit lighter now and more air to cool the engine. Oh well ya win some ya lose some, positive thing though, scoot still runs
