My SYM DD Fatty (mini) Built
da808nanospeed
Post by da808nanospeed »
Thanks for Baka San for the inspiration for converting my DD50 to a stretched with Mini Fatty.
Here are some pics i wanna share.
Before
previous plan
the wheel
Grind off the Ears (exhaust mount)
Moding Mount
test fit
exhaust re angle and custom bracket
put everything together
test drive
Last edited by da808nanospeed on Fri Jul 05, 2013 8:38 pm, edited 1 time in total.
2003 Yamaha R1 998cc SOLD
1997 Honda Elite S 72cc SOLD
2007 SYM DD50 72CC X2
Goped sport 29cc
Re: My SYM DD Fatty (mini) Built
da808nanospeed - nice and clean mount :thumbwink:
LMH
Post by LMH »
Neat custom ride, whats the top speed?
lowblueranger
Post by lowblueranger »
Looka awesome! !
veedubh20
Post by veedubh20 »
stock rim spin fast and more speed.
deuce217
Post by deuce217 »
Sick! What does a rear wheel like that cost with the hub and everything?
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
da808nanospeed
cruise around 50mph, top 60mph . the rear wheel actually is not too heavy compare to stock wheel, because is aluminum. the wheel is an ATV front wheel 10x5. cost around $70, hub i just use Kymco/SYM rear drum hub. The rest need to spend is fabricate the mount, stretch and offset it. also re clock the pipe so it will stick out to clear the wheel. also need to custom a bracket for the pipe.
riding it was very fun, very stable going straight, but a bit hard to turn, not recommend doing sharp turn, or else the kick stand or frame will scrap
Goped sport 29cc
deuce217
Post by deuce217 »
Very cool, thanks. I will look into doiing that on one of my bikes.
50mm BBK (tai)
V-8 pipe
