86 Spree dies as soon as throttle is applied
Got running after about a year. Idol is very fast while on stand, but as soon as throttle is applied even on stand, dies out immediately. Please reply in most layman's terms as possible. This is my first post, and never did much work on Spree before, but willing to try with the help of this great forum. Thanks
- Trafficjamz
Re: 86 Spree dies as soon as throttle is applied
put the air box and make sure the tube to the carb is clamped on tight.
- patthesoundguy
TJ is right that is classic spree, with no air box lid, or cover or hose or all of the above missing or completly out of order. Make sure there is a properly oiled air filter in the airbox as well. The best bet is to replace the filter if you arent sure of its condition they are very inexpensive and needed for proper operation.
Thank you gentleman, I will double check those items and report back. Thanks!
