Clutch pads and springs
markj15062
My 1984 honda spree used to start off real slow and after i got up to speed i was fine until i stopped and had to start again, Now it wont go at all. Like it has no power/grip. Has new carb and drive belt. Do you think my clutch pads and spring could be bad?? help
- patthesoundguy
Re: Clutch pads and springs
Does it rev up without moving, or is it bogging out in the bottom end? Of your clutch was slipping with a worn out belt, it will slip worse with a new belt. Sometimes all the clutch needs is a little touch up with some sandpaper and brake clean to keep it from chattering or slipping. But if all the friction ,material is worn off it will need replacing.
