Where to mount eBay CDI ??
ringLord4
Post by ringLord4 »
I bought this big ole hunk of junk from eBay, now I don't know where to mount it
This didn't work lol.
Re: Where to mount eBay CDI ??
General guideline for any electronics is - mout it away from water drip/splash/dirt/heat/vibration. Stock location is pretty good.
IMHO - the fins are overkill, but if you want - place them so airflow will do it's best for cooling.
patthesoundguy
Post by patthesoundguy »
You could use a hose clamp and clamp it right where it is if it won't go in the stock location. Or maybe fab a bracket to mount it in the stock location.
deuce217
Post by deuce217 »
IMO I would mount that back in the box and return it. The Honda OEM part will be better for you in the long run, way less chance of leaving you, pushing your way home. But if you are unable to fund the honda one, next to the battery would be a good place. I am assuming this is a spree application.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
ringLord4
Post by ringLord4 »
I have the oem. This was a test run
paulpauly7
Post by paulpauly7 »
any difference between the two cdis ? i just found a daytona adjustable cdi with 3 settings Street , Race , Full Race im gonna buy it and see what happens hopefully its good because its daytona honda oem
deuce217
Post by deuce217 »
paulpauly7 wrote:any difference between the two cdis ? i just found a daytona adjustable cdi with 3 settings Street , Race , Full Race im gonna buy it and see what happens hopefully its good because its daytona honda oem
I think the difference is just in the advancement and retarding of the spark. I would stick with OEM. Honda spends plenty of time finding out how to not have predetonation.
50mm BBK (tai)
V-8 pipe
ringLord4
Post by ringLord4 »
I noticed a little difference. Maybe a bit smoother and better response in around 10mph up. Not much though. Will do further testing and post results. :)
As far as honda OEM, ya they may be good but were in the 21st century now, its ok to look for improvements over the past 30 years :happy:
martynkim
Post by martynkim »
Chinese have made no improvements in 30 years. I think they went backwards. I would send it back begging for a refund... :naughty:
ringLord4
Post by ringLord4 »
Astute review of China. Thank you. I'll probably send it back. :)
deuce217
Post by deuce217 »
Nothing wrong with trying new stuff. I just dont believe in chinese electronics. Japan has a level of pride in their products and engineering unparalleled, by any sweat shop in China. If your spree engine is at standard compression it will probable not harm anything. Now if you had high compression and were altering the ignition timing this would be much more risky. Have fun.
50mm BBK (tai)
V-8 pipe
ringLord4
Post by ringLord4 »
Well my compression is gone right now. I have another thread going troubleshooting it
