Spree won't start
dakotabs
Spree won't start
Post by dakotabs »
I purchased a 87 nq50 Spree of craigslist and have only been able to get it running for about 30 seconds. I have read the posts about cleaning the carb and the float pin seat and have had minimal luck. I purchased a new aftermarket carb off ebay and I cant get it to run at all. the new carb has another orifice besides the fuel which I think is for oil injection so I blocked that off because my intake has the oil injection orifice. should I switch carbs again? I have spark and 110 psi compression. the electric start also wont work It will click but wont turn with a good battery.
thanks for the help.
martynkim
Re: Spree won't start
Post by martynkim »
Good move blocking that. Although, the original carb if cleaned properly should out perform it.
dabinonahonda
Post by dabinonahonda »
maybe it wasn't just the carb when i got my first spree the guy had been trying to get it going for two season the first thing i did it replace the reeds ran great after that ...
1988 hd sportster 883 evo
1983 hd sportster 1000 roadster
2001 Honda elite s
dakotabs
Post by dakotabs »
Ok, I checked and cleaned the reed valve and it seems ok, I may order one in the future. After putting on the old carb and and trying to start, I found that I now have no spark. I'm going to clean the points and check the coil.
Finding points on your Spree may prove challenging. Suggest you do some reading.
Tywoo
Post by Tywoo »
I bought that same carb, out of curiosity. It runs pretty decent and i just put on a new petcock from the same company and my spree runs really smooth and hits 30-33 no problem. It took me awhile to get the carb tuned just perfect, bout a day. Not bad parts for the price and quality is pretty good so far :smile:
dakotabs
Post by dakotabs »
Well I have good spark again and put on the stock carb and just cant get it going. could it be the woodruff key/ timing?
If the magnet flywheel was never pulled, not likely. If it was, check it.
martynkim
Post by martynkim »
You might have a petcock problem. fuel in the carb?
dakotabs
Post by dakotabs »
I got it running. when I put on the new carb there wasn't a rubber o ring under the cap assembly so I must have had a air leak. I also put in a new spark plug. Now its time to buy the bbk.
