ZX trans how-to
- paulpauly7
Re: ZX trans how-to
im running the zx rear pulley a 18mm wide belt and i shimmed the front pulley to the extreme limits and a daytona ramp plate on a variated af05e .Works great didnt loose any bottom end gained 6 to 7 mph on the top and a much nicer range of cvt gearing in between
Re: ZX trans how-to
Instead of PMing the pics, please upload them here where everyone can see them. Thanks!evilone wrote:I can pm pics if you want
Re: ZX trans how-to
Have any idea how to post the pics JJ? I use photobucket and the old way of posting pics is not working.evilone wrote:I tried but pics will not show. I tried image code and direct links.
[img]http://i481.photobucket.com/albums/rr17 ... pulley.jpg[/img]
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Re: ZX trans how-to
use imageshack.us its the first forum embed code.
87' spree (SOLD
12' wrx
87' spree (SOLD
12' wrx
- steffen707
Re: ZX trans how-to
ahh the good old days,
I read through all 12 pages to refresh my brain on all the zx stuff. I'm only hitting 57mph on my corsa setup now, I'm thinking either small variator, wrong belt length or possibly too stiff of contra spring may be the culprits. Gotta take everything apart and measure stuff, because its been 2 years or so since I bought my zx stuff.
87 Honda Spree,
XX Yamaha YSR50
92 Yamaha Jog -> Stock.
05 Kymco Super 9-> My cruiser
XX Yamaha YSR50
Re: ZX trans how-to
Here's a nice Japanese-brand ZX pulley with beefy welds. This clutch assembly also includes the clutch shoes & springs (pic 2 on this link is a little mis-leading)
http://japan.webike.net/products/1959399.html
'92 Super Dio ZX - AF18 Corsa
Re: ZX trans how-to
I use/ sourced an OEM SYM drive face (aka: starter motor pulley gear), SYM drive boss, and a SYM rear ZX pulley assembly from Steve @ VT-Cycles and the kick-starter gearing doesn't bind up at all. "NO shimming required".
Re: ZX trans how-to
Kn Brand ZX driven-pulley weld:
- KNZX-pulley-003.jpg (161.78 KiB) Viewed 25385 times
- KNZX-pulley-001.jpg (203.63 KiB) Viewed 25385 times
Re: ZX trans how-to
Looks like a robotic weld. Too perfect is good!
Re: ZX trans how-to
Are there still fitment issues with the cover? After page 10 my mind began to melt
98 Elite
4 strokes are for cars
Re: ZX trans how-to
I know you can't run the rear half of the cover without some major trimming if at all. And the front half just needs a few parts smoothed out, like at the bolt holes they just need to be flattened out, along with the trans cover where the pulley sits needs to be trimmed.
Re: ZX trans how-to
Ok, so the zx trans fits without rear cover. The fitment issues are with the malossi or polini for ruckus vario...only applying to the front cover?
98 Elite
Re: ZX trans how-to
Dont have to, but is the OD of the dio vario the same 94mm?
98 Elite
Re: ZX trans how-to
This is from memory:
Polini for Dio =90.5
Polini for Ruck = 94
