Tire Pressure
Tire Pressure
I have a 1985 Spree. I weigh about 170 lbs. What should I be running for tire pressure? Honda says 18 front/24 rear, it seems low to me.
Those aernt racing tires, irc jetty's please, I have pirellis and those arent even racing tires, theres irc mb750's,dunlop tt91's and there's another from japan ,those are the only 3 RACING tires that I know of?
Michilen s1 is not a racing tire ,it's a good tire but not a TRUE RACE TIRE
Remember,everyone is human,even if there stupid!
- Farfignugin
Best best is to try a variety and see what you like; it's too subject to personal taste and easy to change.Farfignugin wrote:whats a good all-around average tire pressure for front & back?
50 PSI, huh? How's that handling bumps in mid-corner?
Admin, Hondaspree.net
- Farfignugin
Well since i cleaned out the crappy oil i was using and got the right stuff from the honda dealer then used that sea foam crap my top end came back and im hitting 33 sometimes. That seems sorta dicey with the suspension on my bike. Its got 5k miles on it and the shocks are pretty beat down.
I plan on getting my speed into the solid mid 30's and i have some concern about the way this thing bounces all over at high speed.
What sorta stuff can you do? Softer tires are going to make for a smoother ride, if slower. Fatter too, but i just ordered some standard tires and tubes, maybe new will help.
If you are running a spree..a elite shock is a direct bolt-on. Me and darat had our arguements with the actual lifting of the bike...but it raises it an inch or so..it seems stiffer too but i didnt get a chance to ride due to the fact that im rebuildin the engine now. Any input Matt?
1987 Spree 4400 miles 32 mph stock with my 285lb ***
