Hi all,
I have always removed the variator by holding the flywheel side and wrenching the nut on the driven gear. Recently I was giving this advice and it was pointed out to me that this could damage the crankshaft. This seems logical and seems like good advice so I started looking for a tool to hold the driven gear. I am currently working on a 2001 SA50 and pulled out the service manual to read up on removing the variator - here is what I found:
My tendency is to go with what I was told and hold the shaft on the driven gear side but that means waiting til I find a tool (I have a flywheel holder). Has anyone had problems with the crankshaft when holding it still from the flywheel side?
Thanks - obviously there are lots of ways to remove the nut on the driven gear. I really was more concerned about the discrepency between how the manual describes the procedure (holding the flywheel side) and the feedback I received on this forum from a very experienced member.
Really just wanted to find out if the manual is describing a process that could damage the crankshaft. Seems like that would be important to know for all members.
I'm about to finally install my Ruck variator on my nb50 and I came across this thread in search of a safe way to remove the nut without air( no air in my garage right now). I don't believe breazes original question was ever answered.
Is it safe for the crankshaft? I'm thinking this is my only option without air, and also the easiest option as I already have the holding tool.
Also how are you guys holding the crank still while torquing the nut back on??
THANKS!
Google TUSK CLutch Holding Tool for the fastest Pulley Immobilizer in scooterdom.
Seriously? With This tool. I ground some notches into the blades to make it sit down better between the teeth of the outer pulley's Bendix teeth. It's just long enough to reach the ground when clamped onto the pulley, so I don't even have to use my other hand to hold it; just let it swing to the pavement and torque the pulley nut.
Sounds easy as ever and ill probably be ordering one tomorrow. That definitely answers my 2nd question and I appreciate the help. But the question breaze asked, and im still curious about is if its safe to hold the flywheel while installing and removing the variator nut, or will the torque applied somehow damage the crankshaft and/or bearings?
i have done it both ways many times. i think the problem people are afraid of are the crank halves rotating independently from each other since they are only pressed onto the main pin. although i havent ever heard of it happening. anyway i will either use a impact gun on a low setting to remove, or take a sturdy screw driver, and wedge it into the case webbing and firmly against the teeth on the variator drive face while loosening the nut. i have always been able to easily do it that way loosening and re-torquing. even with loc-tite. and it looks like wheelman was implying the variator side being held with the tool.
87' spree (SOLD
12' wrx
Using a torque wrench smoothly, it doesn't seem to matter which end you hold, except removing the shroud is another step. When impact and therefore vibration is added, particularly tighteniing, there is a risk of twisting the crank out of alignment. Yes, I hold the outer vario pulley, but the pins on the tusk can engage the magnet wheel too. I don't currently own an impact gun, but if I did I'd use it only for the rear wheel nut. That one can be tough to crack!
