Hi all,
I am about to fit my new vapor to my scoot. Can i just extend the power and tach cables? I know I can get an extension for the temp sensor. Also how have you fitted the speed sensor? Pictures would help. I am so close to completing the build and a lot of people have helped on here so thanks for that. Just need help with the vapor.
Cheers
Danny
trail tech vapor
Re: trail tech vapor
For the Trailtech Vapor, temp and power leads may be cut and extended with any reasonable sized wire.
The wire will not cause temperature accuracy issues that thermocouple CHTs would see with an extension.
So am I better extending the temperature wire myself or should I buy the extension cable?mousewheels wrote:For the Trailtech Vapor, temp and power leads may be cut and extended with any reasonable sized wire.
Also does the speed sensor go on the front or back?
Cheers
Danny
IMHO - it's your call. Extension is not that expensive. Extending the wire is not that hard and can be done *today*. Electrically either is fine.So am I better extending the temperature wire myself or should I buy the extension cable?
The pickup is ok in either location. Rear mount may require cable extension. Also Trafficjamz had input regarding the rear mount here: Click Me!Also does the speed sensor go on the front or back?
