tuning 28oko and pg long
Re: tuning 28oko and pg long
Okay, Ill check back with results soon. Sad news is th Honda near me wont have the plug until friday.
88 SA 50- Af16e swap
87 Se 50 - 01 Af16E build
Okay check leak down and im good. Changed to a fresh spark plug and lowered the clip (towards the pointed end) 2 notches. Its about 65 out and I pulled 315 at wot for a mile and a half. Temps didnt go above 250 until 1/2 throttle to full throttle. Poor tuning after all. Im pulling mid 60s now with the 9.1 gear set and not running above 325 degrees. Now top get the trans dialed in completely. Hoping for 70+mph
Oh yeahhh buddy
Sup homs ready to ride??
So I am currently running a 160 mj with the needle clip moved up one position from middle. When I go out and ride everything is perfect for about 30min. Once i roll on and am cruising 50ish it cruises fine. If I roll off and then back on it bogs and gargles and slowy drops in rpm. If i come to a complete stop instead of a slow roll it doesnt happen. Would the small clutch spring effect this?
