1988 elite runs too rich and cannot adjust
My 1988 elite will only run a short time without having to clean the plug that is slightly oily but not visibly wet. I have tried starting the air screw adjustment at the 1 3/4 position and gone out from there. When I get out far enough I see dark fuel bubbling from air screw. I have recently replaced carb with one I got on ebay, but suspect it's not OEM. I have checked air cleaner and air path. I suspect some air port retriction, so wondering if OEM carb is best? Any other things I should check before carb replacement?
- paulpauly7
Re: 1988 elite runs too rich and cannot adjust
oem is allways best
How much oil are you adding to the fuel tank?
89 Elite E
I do not add oil to the the fuel tank. i add it to the oil tank and it is injected.
- kingkamehameha
How much compression are u at
I have not checked it, can you tell me the connection between compression and rich burn?
- swimmingfree
i wood get a new plug and set it at 25 and see how thing go from there...
Will try..... Thanks
Sound advice so far. Also check the air filter element. The foam material has a way of going from "open-cell" to "closed-cell" after only a few decades. If it's squishy instead of "springy" it needs replacement. The old filter simply makes the intake draw too rich from excessive intake vacuum.
- kingkamehameha
do a compression test, clean your carb, test the bystarter, check your reeds. Also i always start off with a new plug and filter when doing this type of troubleshooting
Thanks...will give it a try
- swimmingfree
do you no what jet are in the carb you have on the bike ???
were id the pin in the middle of the slide set at ???
has inthing helped ???even a little??
whay are you running the the other carb and not the stock carb???
THanks ...... Going to try the plug and filter suggestions today.
