Opinions on clutch spring
crimespree
Post by crimespree »
85 aero 72cc, what spring would you recommend? i am debating between 1k and 1.5k
Re: Opinions on clutch spring
Lots of speed changes, on/off throttle a lot? 1.5K.
More steady-state part-throttle cruising? +1K.
crimespree
thanks wheelman, ill guess i need to decide which riding i do most
maddog
Post by maddog »
they never made a 72cc kit for the aero unless you have a sa50p engine.
maddog wrote:they never made a 72cc kit for the aero unless you have a sa50p engine.
Maddog said what I was thinking... I'm I slowly becomming like maddog? :?:
martynkim
Post by martynkim »
Stay away from the light, go back!!
deuce217
Post by deuce217 »
Its natural traffic don't worry. They say even kidnap victims start to feel for their capturers after a few years, which from the outside looking in seems crazy but people naturally gravitate to eachother over time.
I also find his snide comments hilarious and now am thuroughly entertained by them.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
maddog
Post by maddog »
you can get a stage 6 clutch and dial it, no i will not tell you how many weights to use in the clutch arms or which springs work= you have a brain -use it.
LMH
Post by LMH »
Clutches are just like variators, user preference is the only real factor.
crimespree
My mistake it is 65cc. I went 1k center. Thinking about going back to stock. Or .5k but I don't think anyone makes that.
paulpauly7
Post by paulpauly7 »
whats wrong with the 1k?
Kevinstonge
Post by Kevinstonge »
paulpauly7 wrote:whats wrong with the 1k?
X2
Also what other mods have you done?
