84 spree BBK with MLM pipe update B-)
- patthesoundguy
Holey moley! I just went for a buzz up the main road and Im very pleased with the reslult. My spree now does pretty much 40 mph now on the flats. The carb, bbk and pipe sure payed off
If I put the gears on woooo it will fly
Re: 84 spree BBK with MLM pipe update B-)
If you're getting that speed on GPS, much respect. Even on Speedometer that's very respectable. By all means, gear up! What pipe are you talking about?
- patthesoundguy
Yup hovers between 38 and 39.7 B-) that is the MLM spree pipe. I was shocked that it went that fast, I was only expecting 35 mph or so. It will hold the 39.7 39.8 consistently on a good flat grade. So from stock my spree was 28mph now it's 39.7 mph B-)Wheelman-111 wrote:Greetings:
Mine has MLM pipe , 70 jet , 2.75 rear tire , all else stock . Just makes 36 GPS on my Garmin .
That is 10,000 RPM . That would be on cool (70 ish) flat road no wind ( and me @ 160 all up).
You must be a good deal past 10,000 ?
- patthesoundguy
11400rpm pretty much on the WOT. I have a digital tachgraphite9 wrote:Id be interested in seeing what rpm your running. Id do gears for sure. Thats great for a spree!
- patthesoundguy
That is a good speed on the stock setup, the pipe makes it happenDust-it wrote:Mine has MLM pipe , 70 jet , 2.75 rear tire , all else stock . Just makes 36 GPS on my Garmin .
- patthesoundguy
I'm still in shock, I never dreamed I'd break 35mph with out the gears. It just a random ride too, I just drove around the yard to my van to get something and went back for the helmet and went up the main road. I'm still buzzing
Im still breaking in the bbk so I figured a 15 trek into down town would be pushing it a little hard
so I hopped on the aero 80 and came to work
- patthesoundguy
The dio motor would be better but its sure fun having it do what it does with the spree motor
Fallout Spree
- Goped
Where do i find one of these pipes?
- patthesoundguy
Devon makes great pipes, I have one on my express as well. Its like bolting on a warp drive to your scooter or moped B-)
- paulpauly7
its a supercharger
