84 spree BBK with MLM pipe update B-)
patthesoundguy
Post by patthesoundguy »
Holey moley! I just went for a buzz up the main road and Im very pleased with the reslult. My spree now does pretty much 40 mph now on the flats. The carb, bbk and pipe sure payed off :-D If I put the gears on woooo it will fly :-D
Re: 84 spree BBK with MLM pipe update B-)
If you're getting that speed on GPS, much respect. Even on Speedometer that's very respectable. By all means, gear up! What pipe are you talking about?
patthesoundguy
Wheelman-111 wrote:Greetings:
Yup hovers between 38 and 39.7 B-) that is the MLM spree pipe. I was shocked that it went that fast, I was only expecting 35 mph or so. It will hold the 39.7 39.8 consistently on a good flat grade. So from stock my spree was 28mph now it's 39.7 mph B-)
Dust-it
Post by Dust-it »
Mine has MLM pipe , 70 jet , 2.75 rear tire , all else stock . Just makes 36 GPS on my Garmin .
That is 10,000 RPM . That would be on cool (70 ish) flat road no wind ( and me @ 160 all up).
You must be a good deal past 10,000 ?
patthesoundguy
graphite9 wrote:Id be interested in seeing what rpm your running. Id do gears for sure. Thats great for a spree!
11400rpm pretty much on the WOT. I have a digital tach ;-) I am running an ax24 belt already. The gears should really help the milage I'm guessing
patthesoundguy
Dust-it wrote:Mine has MLM pipe , 70 jet , 2.75 rear tire , all else stock . Just makes 36 GPS on my Garmin .
That is a good speed on the stock setup, the pipe makes it happen ;-) I was doing 35 on my stock setup you beat me by a mile, right on :-)
patthesoundguy
I'm still in shock, I never dreamed I'd break 35mph with out the gears. It just a random ride too, I just drove around the yard to my van to get something and went back for the helmet and went up the main road. I'm still buzzing ;-) Im still breaking in the bbk so I figured a 15 trek into down town would be pushing it a little hard ;-) so I hopped on the aero 80 and came to work :-)
patthesoundguy
The dio motor would be better but its sure fun having it do what it does with the spree motor ;-)
Fallout Spree
Post by Fallout Spree »
Where do i find one of these pipes?
Dust-it
Post by Dust-it »
patthesoundguy
Devon makes great pipes, I have one on my express as well. Its like bolting on a warp drive to your scooter or moped B-)
paulpauly7
Post by paulpauly7 »
its a supercharger
