VeeDub Gasket Research
Re: VeeDub Gasket Research
Great job guys. I just got 10 of these for 10.00 shipped.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
Pineapplegti
So which of these gaskets are the best to use with a PG short? Has anyone ordered any of these lately?
Hmm, the ones I get from O'Reilly's have a sheetmetal circle. Not sure I'd trust paper only for a big-bore and hot pipe.
Just match up the pipe/exhaust port dimensions and it should be OK.
- Red Eft Performance
Ive run these in the past. You may need to open them up a bit pending on which BBK you have.
http://vwparts.aircooled.net/Exhaust-Fl ... 1-261b.htm
Red Eft Performance
View products click => Here
- kingearwig
that looks like one i found at autozone. i think they were $1.50 or so. 2 layers of metal with what appears to be paper between. fit great on my ruima 50mm
Hppowdercoatings
2001 Elite 72cc...http://www.hondaspree.net/phpBB3/viewto ... =4&t=31369
1984 Spree "Little Evil" 125cc AF16.. http://www.hondaspree.net/phpBB3/viewto ... 16&t=31569
