Fallout's official build thread-questions & concerns
Fallout Spree
Post by Fallout Spree »
Graphite9, you told me I make too many threads, so here it is. I will post all my questions about my build on this thread from now on, starting with this- Do all parts from a 89 elite interchange with a 92? The 92 is "crashed" and I am really hoping the frame isn't bent but if it is ill more than likely swap the motor. Also, the forks seem like they would give a better ride in the 92. Is there a big difference in the motors? Neither of them are any a special restricted model or whatever. Also if anyone has any plastics for these years let me know, any pieces in any usable condition. Thanks
Re: Fallout's official build thread-questions & concerns
i have all sorts of plastics for the elite.
the 89 lx and the 92 should be the same.
Pineapplegti
Post by Pineapplegti »
I have a complete plastic set for an sa50 if you need them
Fallout Spree
Thinking of lowering the spree. If anyone has done this i would like to know how it rides and handles compared to stock.
Fallout Spree wrote: Graphite9, you told me I make too many threads, so here it is. I will post all my questions about my build on this thread from now on,hanks
Postings to this forum are moderated to Performance Technical related.
Prior questions regarding bore kits, carbs, pipes etc are well placed in this forum.
Fallout Spree wrote:....Also if anyone has any plastics for these years let me know, any pieces in any usable condition.
Please post wanted items to the Wanted/For Sale forum with your model and part detail in the subject line.
Fallout Spree
Can anyone tell me if the forks/front wheel/rear wheel off a 92 will bolt on an 89 elite? I like the looks of the 89 more but the wheels and forks look more heavy duty on the 92
Fallout Spree
Does anyone have links to a place where i can find aftermarket rims for an sa50? They dont have to be billet alluminum or anything but id like a different look than stock
paulpauly7
Post by paulpauly7 »
yahoo auctions japan
Fallout Spree
Thank you!
Fallout Spree
Ok what are some good gear combos for a DIO trans? What ones do you run? I'd like to keep bottom end and of course have a good top end
Fallout Spree
Ok thanks
Fallout Spree
Is there any difference in the dio performance vs an afo5e, stock vs stock? Basically I want to know if the dio is heavily restricted from the factory to the point where adding say,a pipe, will gain me more than if I put a pipe on an afo motor
paulpauly7
just build a dio if you want the best from honda .If you want better build up a yamaha jog motor
Fallout Spree
Well I have an afo5e I got for $0, I could buy a dio for 200 but I could use that money for upgrades
bfowler
Post by bfowler »
It just depends what you want to do. If you're looking for about 30-40 then you can stick to the afofe but if you are looking all out speed then go with the dio and like pauly said, if you want EVEN MORE speed than a fully built dio can do, then go with the yamaha jog motor. Judging from all your posts that I've seen you post, I'd have to make an educated guess and say you seem to be fine with the afofe or dio. Honestly you just need to take some time and actually read over posts. Go through the build threads itll teach you a lot.
