Polini Corsa supplied Main jet
LMH
Post by LMH »
Ive recently found the MJ supplied with the corsa is definitely not for the 88+ US elites, I always knew there was a reason I never used them. I just assumed the kits didnt even come with one ha.
If youve used a carb that they worked in let me know.
Red Eft Performance
Re: Polini Corsa supplied Main jet
Post by Red Eft Performance »
The main jet supplied with these kits is for the carb that comes on the Dio. The main jet is different and im pretty sure you can change the pilot on these carbs too.
Red Eft Performance
View products click => Here
LMH
Post by LMH »
Has anyone tried to get a dio carb and use it? I still need to source some jets for that 25mm carb set up, any chance you know where to find them? The local Vespa shop probably can but I always end up buying more than just what I go for so I try to avoid it like the plague.
Red Eft Performance
LoveMyHonda wrote:Has anyone tried to get a dio carb and use it? I still need to source some jets for that 25mm carb set up, any chance you know where to find them? The local Vespa shop probably can but I always end up buying more than just what I go for so I try to avoid it like the plague.
Yes people have used them. Im running off of memory hear so someone correct me if im wrong please. Our elites come with the keihin PA series carb. Different main fixed pilot. The honda Dios (not exactly sure which ones) came with the PB series carb that takes the MAin jets supplied with the kits and has a replaceable pilot jet. Ive seen the genuine used PB carbs on ebay before for a reasonable price. Alot of chinese copys on there now. The new OEM replacement PB carb isnt worth the money might as well go with a proper size carb at that point. You can reconize them cause they have a round bowl. http://www.ebay.com/itm/Dio-ZX-Shadow-D ... 0872273060
Red Eft Performance
Red Eft Performance
LoveMyHonda wrote: I still need to source some jets for that 25mm carb set up, any chance you know where to find them? The local Vespa shop probably can but I always end up buying more than just what I go for so I try to avoid it like the plague.
Ya you can get PHB del jets here. http://www.dellortodirect.com/Parts/PHBL-Parts
Red Eft Performance
LMH
Post by LMH »
You are the man!
paulpauly7
Post by paulpauly7 »
i have a dio carb and manifold .yes the pilot jet is changeable and yes the jet supplied in my corsa box fits the dio carb .Im not sure if im gonna use it yet or not .
LMH
Post by LMH »
Arent the dio intakes different bolt pattern than the af16? If not want to sell an intake and carb pauly?
paulpauly7
i dont think they are different the ct intake bolts up fine to both engines i will talk to NZHONDA he also has a intake manifold and carb spare he is also heading to the states tomorrow so he could take it with him save shipping costs ill give him a call now
LMH
Post by LMH »
Awesome thanks pauly!
Apparently the case intake port bolt pattern is the same on the AF18-later AF series engines. Methinks Mousewheels was referring to wider bolt spacing at the carb flange on the PB carb, something I'd read before.
paulpauly7
well i couldnt get ahold of him so i sent him a txt .I know hes is leaving here today .I he didint manage to take it then ill find out how much shipping would be
LMH
Post by LMH »
So you have to run the af18 air box or the dd50 air box as well it seems. With the replaceable pilot tho it would just make sense to run a uni with it like I did with the 4t,minas, and piaggio. Id like one of them carbs and intakes or I need to fashion an adapter to mount a mina 19mm carb. I have a couple of them at least.
bonesv
Post by bonesv »
LoveMyHonda wrote:So you have to run the af18 air box or the dd50 air box as well it seems. With the replaceable pilot tho it would just make sense to run a uni with it like I did with the 4t,minas, and piaggio. Id like one of them carbs and intakes or I need to fashion an adapter to mount a mina 19mm carb. I have a couple of them at least.
I'm currently running a dio intake/pb carb setup. I have an air box from a '90 dio sr. Slight mods to mount the air box, and had to drill/tap for a new vacuum nipple on the intake manifold. I like the stock look but it's a stock motor, well, almost. :twisted:
