cruzingratiot
Post by cruzingratiot »
the bike 2000 purple eliteS
some of the parts
oko air box
polini corsa 72cc polini variator
phongeer short 8.5 gears
for carburators I have a 28mm oko, 28mm keihin but thinking about using a mikuni tm28
waiting on new crank bearings and seals should be in Thursday
before I tear into it
for tires Metzeler ME1 had them on my street bike at one time
Paul
if you have a NCY caliper
ebc pads will fit the top smaller holes are not used
NCY 1000-1314 Brake pads
EBC SFA193HH
EBC FA193
RPM 10"x2.15J Front Wheel (Dio TDM, Black) - 44650-GW0-R02B
RPM 10"x2.15J Rear Wheel (Dio, Black) - 42601-GW0-R02B
EDIT 11-18-2013 add part numbers
polini corsa pn 119.0077/r
polini corsa replacement piston kit pn 204.0690
polini replasment gaskets base o ring exhaust kit 209.0383
HiT clutch from Dr. Pulley HIT161301
polini 3 shoe clutch pn 249.049
polini variator pn 241.480
phongeer alloy drive face AL7075T6
polini 24mm carburetor pn 201.0166 CARBURETOR D.24
Trail Tech TTO Temperature Meter Black Digital Gauge 14mm pn 722-ET3
malossi crank ? 53 7604
CT intake
polini 3 spring set 245.085
green 4,000-5500 yellow 5500-6500 blue 6500-7500
3g blue springs 245.072
malossi yellow contra 297042Y0
malossi red contra 297043R0
3-2015
Stage 6 Oversize Valve intake #S6-3217500
Headlight Honda elite 2001 35w/35w PN 33120-GS7-A81
& rubber cover for bulb PN 33180-MR7-003
HS1 bulb Phillips # 12636C1 HS1
4-13-2015 edit
(heard was called kuka airbox )
(DDX airbox is same with only one slit on bottom)
edit 5-15-2015
naraku NK901.17 clutch bell modified
http://hondaspree.net/phpBB3/viewtopic. ... 50#p248550
more expensive and brighter than the ( Phillips # 12636C1 HS1) headlight but changed it to
Osram Silverstar HS1 (PX43t) 35/35w 12v Bulb [64185SVS-01B]
Windjammer EURO-RACING Chamber w-1274-129
non tinted taillight Kymco DJ50 OEMpart No.: 33700-GS7-E000.
Kymco DJY 50 Refined (PR50A) 93-06
204.0690 corsa replacement piston stock bore
166.0079 chrome top ring
206.0200 cast bottom ring
209.0383 gasket kit
204.0686 piston sfera-honda d.47,4 com 24,5 1.o/s, ├ÿ 47,4mm
take # below at your own risk
I am 99% shure there right
2001 Honda ELITE S (SA50P) - Body Cover
COVER, R. BODY *NH1* (BLACK)
Part Number: 83450-GS7-A90ZA
COVER, L. BODY *NH1* (BLACK)
Part Number: 83550-GS7-A90ZA
COVER SET, R. BODY *R191* (WL) (AMERICAN RED)
Part Number: 83450-GS7-A90ZB
COVER SET, L. BODY *R191* (WL) (AMERICAN RED)
Part Number: 83550-GS7-A90ZB
2001 Honda ELITE SR (SA50)
Part Number: 83450-GS7-A80ZA
Part Number: 83550-GS7-A80ZA
Part Number: 83450-GS7-A80ZB
Part Number: 83550-GS7-A80ZB
2000 Honda ELITE S (SA50P)
COVER, R. BODY (TYPE2)
Part Number: 83450-GS7-850ZB Mystic purple P24P
COVER, L. BODY (TYPE2)
Part Number: 83550-GS7-850ZB Mystic purple P24P
2000 Honda ELITE SR (SA50)
COVER, R. BODY (TYPE1)
Part Number: 83450-GS7-840ZA Mystic purple P24P
COVER, L. BODY (TYPE1)
Part Number: 83550-GS7-840ZA Mystic purple P24P
1999 Honda ELITE S (SA50P)
Part Number: 83450-GS7-850ZA color ?
Part Number: 83550-GS7-850ZA color
83450-GS7-850ZA a rh ? was for sale on
ebay it was yellow coudhave been a typo
1999 Honda ELITE SR (SA50)
Part Number: 83450-GS7-840ZA color ?
Part Number: 83550-GS7-840ZA color ?
1998 Honda ELITE S (SA50P)
Part Number: 83450-GS7-850ZB color ?
Part Number: 83550-GS7-850ZA color ?
1998 Honda ELITE SR (SA50)
1997 Honda ELITE S (SA50P)
1997 Honda ELITE SR (SA50)
1996 Honda ELITE S (SA50P)
1996 Honda ELITE SR (SA50)
1995 Honda ELITE S (SA50P)
COVER *R110* (TYPE1) (MONZA RED)
Part Number: 83450-GS7-980ZA
Part Number: 83550-GS7-980ZA
COVER *NH1* (TYPE2) (BLACK)
Part Number: 83450-GS7-980ZB
Part Number: 83550-GS7-980ZB
1995 Honda ELITE SR (SA50)
Part Number: 83450-GS7-860ZA
Part Number: 83550-GS7-860ZA
1994 Honda ELITE S (SA50P)
1994 Honda ELITE SR (SA50)
Part Number: 83450-GS7-970ZA
Part Number: 83550-GS7-970ZA
1992-1993 Honda ELITE SR (SA50)
COVER, R. *NH1* (BLACK)
Part Number: 83504-GS7-000ZD
COVER, L. *NH1* (BLACK)
Part Number: 83604-GS7-000ZD
1989-1990 Honda ELITE SR (SA50)
COVER, R. BODY *R134* (FIGHTING RED)
Part Number: 83504-GS7-000ZC
COVER, L. BODY *R134* (FIGHTING RED)
Part Number: 83604-GS7-000ZC
COVER, R. BODY *PB211* (CORAL BLUE)
Part Number: 83504-GS7-000ZM
COVER, L. BODY *PB211* (CORAL BLUE)
Part Number: 83604-GS7-000ZM
1988 Honda ELITE SR (SA50)
fighting red same as 1989-90
COVER, L. BODY *NH138* (SHASTA WHITE)
Part Number: 83604-GS7-000ZA
yellow s rh side cover
CVR, R. BODY (TYPE1)
(83450-GS7-850ZA)
sr side panels black
83450-GS7-840ZA
CVR, L. BODY (TYPE1)
83550-GS7-840ZA
Hoods
black hood plain
64301-GS7-000ZD
Mystic purple hood
64301-GS7-000ZX
2001 black hood COVER SET, FR. *NH1* (BLACK)
64300-GS7-A80ZA
COVER SET, FR. *R191* (WL) (AMERICAN RED)
64300-GS7-A80ZB
SA50PA (00) MOTOR SCOOTER,
COVER SET, FR. (TYPE2) (WL)
64300-GS7-850ZA
COVER SET, FR. (TYPE1) (WL)
64300-GS7-850ZB
SA50PA (99) MOTOR SCOOTER,
64300-GS7-850ZA
64300-GS7-850ZB
SA50PA (98) MOTOR SCOOTER
64300-GS7-850ZA
64300-GS7-850ZB
SA50PA (97) MOTOR SCOOTER
64300-GS7-850ZA
64300-GS7-850ZB
SA50PA (96) MOTOR SCOOTER
64300-GS7-850ZA
64300-GS7-850ZB
SA50PA (95) MOTOR SCOOTER
COVER SET, FR. *NH1* (WL) (BLACK)
64300-GS7-A80ZA
Previous part number
64300-GS7-980ZB COVER SET, FR. *NH1* (TYPE2) (WL) (BLACK)
1994 (SA50P)
64300-GS7-A80ZA
COVER, FR. (TYPE1)
64300-GS7-970ZA
1994-1995 Honda ELITE
CVR *R110* (MONZA RED)
64300-GS7-980ZA (1995 note replaces 64300-GS7-860ZA)
COVER, FR. (TYPE1)
64300-GS7-890ZA
1988-1989-1990 Honda ELITE SR (SA50)
COVER, FR. *R134* (FIGHTING RED)
64301-GS7-000ZC
SA50A (89) MOTOR SCOOTER
COVER, FR. *PB211* (WOL) (CORAL BLUE
64301-GS7-000ZN
SA50A (88) MOTOR SCOOTER
COVER, FR. *NH138* (WOL) (SHASTA WHITE)
64301-GS7-000ZA
yellow hood
part # 64300-GS7-850ZB CVR, FR. (TYPE1)
red hood plain
64301-G57-000ZM what red ???
black headlight cover
53205-gs7-670ze
*Y135P* (PEARL RIO YELLOW) headlight cover
53205-GS7-670YB
P24P purple headlight cover
53205-GS7-670YA
*R191* (AMERICAN RED) headlight cover
53205-GS7-670YE
FR. *R110* (MONZA RED) headlight cover
53205-GS7-670ZH
*R134* (FIGHTING RED) headlight cover
53205-GS7-670ZB
. *NH138* (SHASTA WHITE) headlight cover
53205-GS7-670ZA
COVER, FR. *PB211* (CORAL BLUE)
Part Number: 53205-GS7-670ZJ
NH1 black front under fender
61100-GS7-000ZK FENDER FRONT
side skirts
COVER, R. SIDE *NH1R* (WOL) (BLACK)
83520-GS7-000ZJ
83520-GS7-000ZK COVER, R. SIDE *NH1* (BLACK)
COVER, L. SIDE *NH1R* (BLACK)
83620-GS7-000ZJ
83620-GS7-000ZK COVER, L. SIDE *NH1* (BLACK)
little part in lh cover
LID, SIDE COVER *NH1R* (BLACK)
83630-GS7-000ZN
83630-GS7-000ZP LID, SIDE COVER *NH1* (BLACK)
COVER, R. SIDE *NH201R* (WOL) (HUSKY GRAY)
83520-GS7-000ZH
COVER, L. SIDE *NH201R* (WOL) (HUSKY GRAY)
83620-GS7-000ZH
LID, SIDE COVER *NH201R* (HUSKY GRAY)
83630-GS7-000ZH
1988: Shasta White, Fighting Red
1989: Coral Blue, Fighting Red
1990: Coral Blue, Fighting Red
1991: Coral Blue, Fighting Red
1992: Black
1993: Black
1994: Gloss Black, Monza Red
1995: Gloss Black, Monza Red
1996: Pearl Majestic Purple, Pearl Hot Rod Yellow
1997: Pearl Majestic Purple, Pearl Rio Yellow
1998: Pearl Majestic Purple, Pearl Rio Yellow
1999: Pearl Majestic Purple, Pearl Rio Yellow
2000: Pearl Majestic Purple, Gloss Black, Carbon Grey
2001: Gloss Black, American Red
nos 2001 halogen 35w headlight 33120-gs7-a81
edit 10-12 2016 add part # for future refrence
Last edited by cruzingratiot on Tue Apr 13, 2021 2:47 pm, edited 77 times in total.
Donate Life
http://www.donatelife.net/
Thank You
bfowler
Re: 2000 Mystic Purple Elite build
Post by bfowler »
What about a CHT and a tach???:D
Limp1144
Post by Limp1144 »
Where did you get the oko air box it looks sweet will it fit a kymco zx 50 you think
cruzingratiot
bfowler wrote:What about a CHT and a tach???:D
they are on order
Limp1144 wrote:Where did you get the oko air box it looks sweet will it fit a kymco zx 50 you think
he list it as fitting
PERFORMANCE AIRBOX for the 1994 and up Honda Elite DIO SA50, SR50, SK50, SYM DD50 /JOLIE and KYMCO ZX.
got it from daywot in Honolulu, Hawaii,
he also has them 4 sale on ebay
http://www.ebay.com/itm/PERFORMANCE-AIR ... 3f25d4e51d
Paul
jet drill size chart
Donate Life
Thank You
deuce217
Post by deuce217 »
Never seen ARP Studs used, Sweet! What is your total parts cost at so far?
New tires too! I am really diggin the looks of the Continental Zippy 90/90-10 tires they look like they were designed for turning at high speeds.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
bfowler
Post by bfowler »
deuce217 wrote:Never seen ARP Studs used, Sweet! What is your total parts cost at so far?
Are new studs needed when installing a corsa?
LMH
Post by LMH »
I think hes using metzlers.
No, actually studs are not recommended for the Italian bores from what all the engine builders have told me in the past.
LMH
Post by LMH »
Nice scooter! I love my mystic purple '99 also, never thought I could love a purple scooter.
paulpauly7
Post by paulpauly7 »
i use studs on my corsa all my parts were supplied by tru72 and he knows his stuff
cruzingratiot
actually they are arp bolts didn't want to reuse stock bolts
don't really want to keep track of what I spend
12-28-2014
Added ARP bolt information
90mm legnth
Last edited by cruzingratiot on Sun Dec 28, 2014 9:47 pm, edited 2 times in total.
Donate Life
Thank You
deuce217
Post by deuce217 »
I understand that! I have a ton wrapped up in my shop right now. Maybe 10k in scooters. Worth every last penny!
p.s. Anybody have some change? I'm broke. :coolcruise:
50mm BBK (tai)
V-8 pipe
cruzingratiot
picked up a rear JDM ? grab bar today
to go with my kymco taillight
tear down starts soon pics to follow
Donate Life
Thank You
bonesv
Post by bonesv »
cruzingratiot wrote:picked up a rear JDM ? grab bar today
Nice work! I'm sure some would like to know how to get a jdm grab bar for their scooter.
Is there a link you could post?
cruzingratiot
wish I could buy another no link got lucky
bought it from a friend of a friend who is putting a stock taillight back on
Donate Life
Thank You
bfowler
Post by bfowler »
Ewwww replacing the JDM tails with stock tails?! d*** I wish I could get my hands on one of those grab bars
