best gearing for my strokah..
JAC3
Post by JAC3 »
52.6
54mm
2000 grab
2000 torque
pg long
30mm carb
goal 90mph plus highway
just cant decide what gear to run i have
8.4-1
8.0-1
6.8-1
6.5-1
5.5-1
zx trans 54grams
was running 6.5-1 but it feels like something is holding it back motor wants to go more..i think belt slippage.
havent clock with gps yet but i bury 90mph on the pg speedo dont know if its accurate what do you guys think?..
now im running 6.8 sounds and feels better..
what can i don to improve my setup maybe hit 100mph..hehe
LMH
Re: best gearing for my strokah..
Post by LMH »
What tires are you running going that speed. Too long on a wrong rates tire can be trouble. Get a pic of that bad boy doing 90 on the speedo. I'm planning on running 6.8s on my w/c 121cc. I run Pirelli diablos on my 91 mph Zx. But those are 12" wheels and I need a killer set of 10s for the elite.
JAC3
Post by JAC3 »
LoveMyHonda wrote:What tires are you running going that speed. Too long on a wrong rates tire can be trouble. Get a pic of that bad boy doing 90 on the speedo. I'm planning on running 6.8s on my w/c 121cc. I run Pirelli diablos on my 91 mph Zx. But those are 12" wheels and I need a killer set of 10s for the elite.
Michelin 90 90 10.. yeah ill try to get pic...
JAC3
Post by JAC3 »
Bump anyone ?..
JAC3 wrote:Bump anyone ?..
I have some 6.3:1 gears that would be perfect for your goal.
Any gears over 7.5:1 will be to short to go 90mph :imo:
Is that the big PG for strokers?
JAC3
Post by JAC3 »
so anything under 7.5 is good to go 90mph?.. i dont wanna lose any lower mid power.its a tida bore square once..
JAC3
Post by JAC3 »
installed 6.3-1 gearing and only hit 75mph with gps..
JAC3 wrote:installed 6.3-1 gearing and only hit 75mph with gps..
ive hit 75mph on 7.5:1 gears. you need to rev higher.
What rpm's are you seeing?
JAC3
Post by JAC3 »
Hi.. my tach wasn't installed at that time I will install and find out today.. To get higher rev go down on the weights right? I had 3 8g and 3 9grams..i marked the vara and belt goes all the way up.. Thanks
Here is the official trafficjamz "speed chart"
10000 rpms + 6.3 gears + maxed out variator(0.8:1 ratio) + 90/90 rear tire = 90.8 mph
JAC3
Post by JAC3 »
hey i did a test run today with my tach at wot the rpm it climbs up to 6,500 but drops back down and stayed 5,500rpm.. my fastest speed gps at 68mph..Tried swapping exhaust with my buddy pg long..
paulpauly7
Post by paulpauly7 »
man them rpms are low my corsa spools up to 10k then goes up once the cvt is maxed ive seen a max of 11690
JAC3
Post by JAC3 »
Yeah I don't know what holding it that low.. Maybes reed valve
paulpauly7
maybe that pg pipe aint so good on a full stroker ?
maybe jetting or porting ? whats your temps at?
JAC3
Post by JAC3 »
paulpauly7 wrote:maybe that pg pipe aint so good on a full stroker ?
30mm oko
152 main clip all the was up..
48 pilot
temp is at 250-280 WOT about quarter mile..
around town temp it at 170-190
ported opened intake and matched boost port..
ct intake sweats a lot almost dripping wet..
i think i can lean it out more maybe 150
