$20.00 Craigslist 199??? Honda Tact Build
I found a 199? Honda Tact on craigs list . It,s very similar to a Aero and some parts can be swapped .
Which helped a lot but there are also a lot of slight differences which can be a real mess.
The ad said pair of mopeds - $100 as soon as I saw it I knew one was a Honda I went down and met with the seller
and said I was not interested in the Chineese scoot and how much for just the Honda he said how about $20.00
Done deal ....
Here,s what happened next .
Done deal ....
- Craigslist Ad
- my $20.00 scoot.jpg (46.97 KiB) Viewed 14956 times
- First look
- 100_4733.jpg (53.98 KiB) Viewed 14956 times
- Looks like most parts are there
- 100_4732.jpg (52.37 KiB) Viewed 14956 times
Re: $20.00 Craigslist 199??? Honda Tact Build
Next get it home .
- 100_4738.jpg (71.26 KiB) Viewed 14955 times
- 100_4735.jpg (38.66 KiB) Viewed 14955 times
- 100_4734.jpg (50.28 KiB) Viewed 14955 times
Before I went any farther I wanted to see if it would run .
Rather than doing a bunch of work on a scoot that didn,t run .
Took less than 20 min. sprayed some starting fluid in the carb
put in a battery , tried the elect. starter click click tried the kick start
once, twice , waaaaaah bam bamm waaaaaahh
Clouds and clouds of white smoke just pouring out ...Waaaah waaaaaah
kept running it after a while the white smoke diminished .
I was a happy guy ...
- Clouds and clouds of white smoke
- 100_4743.jpg (38.88 KiB) Viewed 14954 times
- 100_4778.jpg (73.22 KiB) Viewed 14954 times
- 100_4752.jpg (72.18 KiB) Viewed 14954 times
Next started on the cosmetics
- 100_4887.jpg (49.89 KiB) Viewed 14954 times
- 100_4753.jpg (55.37 KiB) Viewed 14954 times
- 100_4756.jpg (46.9 KiB) Viewed 14954 times
Lucked out the original seat had a OK seat cover ,
Which had screws holding it on .
- 100_4788.jpg (53.63 KiB) Viewed 14901 times
- old seat.jpg (46.97 KiB) Viewed 14954 times
- 100_4789.jpg (42.09 KiB) Viewed 14954 times
Plastics total mess looked like 5 different coats of paint silver / gold / white / black / thick blue
- 100_4747.jpg (77.54 KiB) Viewed 14954 times
- 100_4917.jpg (45.18 KiB) Viewed 14954 times
- 100_4919.jpg (48.99 KiB) Viewed 14954 times
Still more work on plastics sand / bondo / sand / bondo / primer / sand / sand ...
- 100_4966.jpg (37.68 KiB) Viewed 14953 times
- 100_4945.jpg (47.57 KiB) Viewed 14953 times
- 100_4915.jpg (36.65 KiB) Viewed 14953 times
A lot of the screw inserts on the front were cracked or broken
I used some clothes pins and plastic glue then bailing wire to hold it together
while it set .
while it set .
- 100_4951.jpg (54.24 KiB) Viewed 14952 times
- 100_4970.jpg (39.35 KiB) Viewed 14952 times
- 100_4974.jpg (37 KiB) Viewed 14952 times
Then started doing some cleaning up .
Used every type of de-greeser I had then scraping then wire brush .
Then Grey paint .
Then Grey paint .
- 100_4792.jpg (51.99 KiB) Viewed 14952 times
- 100_4759.jpg (46.75 KiB) Viewed 14952 times
- 100_4819.jpg (25.16 KiB) Viewed 14952 times
More plastics
- 100_4838.jpg (59.34 KiB) Viewed 14952 times
- 100_4798.jpg (70.57 KiB) Viewed 14952 times
- 100_4876.jpg (38.31 KiB) Viewed 14952 times
Could not find an air cleaner cover anywhere .
It seemed to run OK w/o one so I thought I could make my own .
Used the plastic from a re cycle bin .
- 100_5012.jpg (30.45 KiB) Viewed 14951 times
- 100_5010.jpg (39.39 KiB) Viewed 14951 times
- 100_4982.jpg (45.43 KiB) Viewed 14951 times
more plastic sheet
- tail 7.jpg (37.75 KiB) Viewed 14951 times
- tail old .jpg (33.74 KiB) Viewed 14951 times
- tail new.jpg (57.93 KiB) Viewed 14951 times
Things finally started coming together .
- 100_4890.jpg (38.18 KiB) Viewed 14951 times
- 100_4888.jpg (60.74 KiB) Viewed 14951 times
- 100_4847.jpg (61.06 KiB) Viewed 14951 times
more stuff
- 100_4906.jpg (58.03 KiB) Viewed 14951 times
- 100_4900.jpg (59.65 KiB) Viewed 14951 times
- 100_4899.jpg (60.34 KiB) Viewed 14951 times
So close
- 100_5022.jpg (42.2 KiB) Viewed 14951 times
- 100_5000.jpg (42.82 KiB) Viewed 14951 times
- 100_4907.jpg (50.86 KiB) Viewed 14951 times
