1980s Honda Melody Build - GY6 swap
Re: 1980s Honda Melody Build - GY6 swap
Yeah go for it. Im gunna buy a tuned pipe program in the next week so I can start on my exhaust. What sort of power numbers should I use and at what RPM? Cause I have no idea at this stage haha
- paulpauly7
thats the hard part building a tuned pipe is way way harder than you think ive made a couple that worked well but to get to that point i made and cut and modified the original like 20 or so time to get it right
Oh ok. Im probably being a bit ignorant about it. Have you any suggestions what I could do or where to start for an exhaust?
- paulpauly7
get your hands on a chamber pipe for something else cut the chamber off cut your stock pipe off where the muffler meets the header pipe and weld the chamber on and go from there .Shorten or lenghen the header and so on .I had better luck and less welding doing it this way
that sounds easier. Dont spose you have one lying around that could work?
- paulpauly7
not at the mo sorry
