carb has no main jet?!?!
- Dingus Khan
- Goped
1982 honda sky stock carb and there is no main jet?? Its just a hole with no threads or anything to unscrew. Anyone ever seen this?
- carb.jpeg (203.44 KiB) Viewed 7220 times
Re: carb has no main jet?!?!
That looks identical to a spree carb. Can you take more pictures?
- Dingus Khan
- Goped
yeah. I had someone on here take a look at it in person and I think he said it was different than a spree carb it was more like an aero or tact I forgot now.
- patthesoundguy
It could be like the express carb and have a fixed main jet, it looks like that
- Dingus Khan
- Goped
that's what he said it was an express!
- Dingus Khan
- Goped
I pulled my spree carb and took side by side pics. the main and I think only differences is the "butt hole" is slightly larger on the spree and one of the needle holes screws on and and on the spree one has a clip that holds it down.
- patthesoundguy
It sure looks like an express carb
- patthesoundguy
Any more pics side on?
- martynkim
It looked like this. http://www.youtube.com/watch?v=MIC-B7QoKFI Without soaking it I wasnt certain how to clean it. If it matches the intake side you could bolt on the Spree carb and rejet it.
- Dingus Khan
- Goped
- martynkim
Match where they bolt on at. I found this too, I forgot about it. http://www.hondaspree.net/phpBB3/viewto ... =3&t=13474
Check this out too. http://www.youtube.com/watch?v=6jgseAKHIAM
- Dingus Khan
- Goped
Forgot the bolt on side pics but they are exactly the same.
- 10.jpeg (249.5 KiB) Viewed 7174 times
- 9.jpeg (234.95 KiB) Viewed 7174 times
- paulpauly7
just bolt on that spree carb and do a couple of plug chops to see where its at in the way of jetting
- martynkim
paulpauly7 wrote:just bolt on that spree carb and do a couple of plug chops to see where its at in the way of jetting
Exactly, give it a go or bring it by again.
- Dingus Khan
- Goped
The "needle valve" on the lower left has totally different connections. The sky on the right screws down there the spree just sits in there and has a clip to hold it in. Also the sky has a round thing where the spree has 2 needles. Ill snap pics in the am.
