carb has no main jet?!?!
Dingus Khan
Post by Dingus Khan »
1982 honda sky stock carb and there is no main jet?? Its just a hole with no threads or anything to unscrew. Anyone ever seen this?
dakotabs
Re: carb has no main jet?!?!
Post by dakotabs »
That looks identical to a spree carb. Can you take more pictures?
Dingus Khan
yeah. I had someone on here take a look at it in person and I think he said it was different than a spree carb it was more like an aero or tact I forgot now.
patthesoundguy
Post by patthesoundguy »
It could be like the express carb and have a fixed main jet, it looks like that
Dingus Khan
that's what he said it was an express!
Dingus Khan
I pulled my spree carb and took side by side pics. the main and I think only differences is the "butt hole" is slightly larger on the spree and one of the needle holes screws on and and on the spree one has a clip that holds it down.
patthesoundguy
It sure looks like an express carb
patthesoundguy
Any more pics side on?
martynkim
Post by martynkim »
It looked like this. http://www.youtube.com/watch?v=MIC-B7QoKFI Without soaking it I wasnt certain how to clean it. If it matches the intake side you could bolt on the Spree carb and rejet it.
Dingus Khan
Pics
martynkim
Post by martynkim »
Match where they bolt on at. I found this too, I forgot about it. http://www.hondaspree.net/phpBB3/viewto ... =3&t=13474
Check this out too. http://www.youtube.com/watch?v=6jgseAKHIAM
Dingus Khan
Forgot the bolt on side pics but they are exactly the same.
paulpauly7
Post by paulpauly7 »
just bolt on that spree carb and do a couple of plug chops to see where its at in the way of jetting
martynkim
Post by martynkim »
paulpauly7 wrote:just bolt on that spree carb and do a couple of plug chops to see where its at in the way of jetting
Exactly, give it a go or bring it by again.
Dingus Khan
The "needle valve" on the lower left has totally different connections. The sky on the right screws down there the spree just sits in there and has a clip to hold it in. Also the sky has a round thing where the spree has 2 needles. Ill snap pics in the am.
