I have a Different Effective way of cleaning the Carb.
- Farfignugin
kurremkarm
- Farfignugin
- Farfignugin
- mopedman
you all are soooo dumb why dose everyone argue about every thing in every post, the guy that put up this post was trying to be helpfull, i am going to try it and see if it works good and if it dose i am going to put it in tec docs
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
2005 Yamaha Zuma
1985 Honda Spree
1978 Honda Express
Sorry, noiseguy already put in in there almostly immediately after this thread started.mopedman wrote:you all are soooo dumb why dose everyone argue about every thing in every post, the guy that put up this post was trying to be helpfull, i am going to try it and see if it works good and if it dose i am going to put it in tec docs
I have a 1986 red Honda Spree
mods: uni prefilter, two 3/8 inch holes drilled in airbox lid, drilled jet out from .026 to .0292.
I also have a 1999 Yamaha Blaster
stock except Graydon Proline Nerfs Holeshot tires and aluminum rims.
ummm, i'm guessing the reason you are running faster is because you are decarbonizing your head when you run that stuff. same effect as misting water into a carb, except it's safer.
sure it probably cleans the carb too, but seriously, how lazy can you be not to just take the carb off and spend seven minutes cleaning the thing. then you can use compressed air and be sure that everything is clean and then inspect it too.
btw - i don't like the stuff. i call it headgasket eater cause it cleans out so many deposits in cars that it leaves holes where deposits used to be. on a moped it probably doesn't matter as much though - so go nuts.
1980 motobecane sebring : 1989 razz : 1985 spree : 1987 spree : 1986 spree : 2002 yamaha vino :1971 cb100 : 1998 civic : 2002 s2000
