spree bbk and 21mm jetting
- bbrmotosports
- Goped
What main jet should I start with on my spree. Got the tax bbk and 21mm carb kit with a mlm. Kit came with a 102 and a 95
84 Mod spree
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
- swimmingfree
Re: spree bbk and 21mm jetting
when braking in a new jug you need to be cool with it run some exter oil in the tank and do some heat cycle as well ..
- bbrmotosports
- Goped
I already "broke it in" in stock form.
84 Mod spree
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
- patthesoundguy
I'm having great luck with a 95 main and 45 pilot. I had to set mine up from scratch because I got the carb setup from someone who had got it from taz and never installed it but robbed the jets out of the carb so I bought the two jet kits and went to it
and I have the first mlm spree pipe He made so you should be good to go with the 95.
- bbrmotosports
- Goped
What kind of filter are you running?
84 Mod spree
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
- patthesoundguy
http://dx.com/p/48mm-diameter-universal ... rey-189442
About 8$ free shipping. Its nice and quiet too
OneHungLOWe
Is it necessary to change the air filter when you add a big bore kit? I just purchased my 1986 spree and have plans to make it faster. I have the big bore kit, performance CDI and coil kit, as well as a new jet for the carb......am I on the right track? I got the bbk off of ebay from chopchop...he said it was bolt and go and it came with the a new jet. I look forward to hearing from y'all.
- patthesoundguy
Yes that kit needs a lot more air and needs free flow to not be too rich when you install that jet with the kit in the stock carb. you can do one of two things mod the airbox according to the instructions that taz includes in the kit, or use an after market filter that fits the stock carb. A uni filter part number that fits is in the instructions. A super easy cheap way to mod the air box are these
http://www.mfgsupply.com/ufv-6.html. Thats the way i would go. Get a cheap step drill at the hardware store and mod the air box with those little plugs
I would also save up for the carb kit it really helps.
- bbrmotosports
- Goped
Yes, you need to A: flow more air and B: the stock air box boot will not fit the new carb. I ended up going with a uni twin stage filter.
84 Mod spree
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
- bbrmotosports
- Goped
I can't get this thing to run worth a crap. I was able to hit 40 mph with the stock pipe. Put the mlm on todayand it does 30. CCan't figure out jetting
84 Mod spree
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
- swimmingfree
Put the mimon today and it does 30. CCan't figure out jetting
what is mim ?????
what is mim ?????
- patthesoundguy
He means the MLM pipe.
- swimmingfree
pull the plug ill bet its black...
- bbrmotosports
- Goped
Electrode is brown, tried a 95 main, 100 main and 105 main, tried a 45 and 50 pilot moved the needle in every position, still cant get it to even hit the powerband. Is anyone else running this set up with ChopChop's gears? According to the plug it's jetted good in my eyes but obviously not. Also when the engine is warm you have to hold it half throttle for it to start.
84 Mod spree
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
13 CBR500R
11 CBR250R
05 CR125R
04 KTM450SX
- paulpauly7
id drop your pilot to a 42 maybe even a 40 and put the 95 main in with the clip one up from center.also if you google plug chop the tip colour is not a accurate reading .You need a new plug and you want to look at the ring right at the bottom of the electrode looking down into the plug.Sometimes it can be hard to see so you need to use a magnafieing glass
