Ran into an amazing deal on a second 1994 Honda Elite SR50 dio.
It needs a top-end anyways, so I am wondering if there are any BBK that can be installed right in place of the stock and use all stock parts carb and pipe.
I will change the variator and gearing because that can be done on a stock scooter for much improved performance.
Anything this easy that is worth the time and keep it reliable?
Dio Big bore swap and go?
Re: Dio Big bore swap and go?
you can do it but its not recommended...
1988 yamaha zuma
polini evolution kit
polini evolution 2 exhaust
polini big reed manifold
dellorto 21mm
keli clutch
keli variator
dellorto 21mm
keli clutch
keli variator
you can do that with pretty much all the stock stroke big bore kits. I was running a char mo 50mm bore with non ported case on my 96 elite s with stock carb ,stock exhaust and 9to1 gears and had that setup on my bike for over 7years with no issues at all.I just tied open the oil injector,ran motul 710 oil and about an ounce of oil per tank full. upjetted to a 88 and thats it. buried the needle on the flat no problem.you just wont get the full power of the kit but good enough.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
That sounds perfect. What's the point in adding oil the the fuel? Does that not lean the fuel mixture somewhat? I always thought it allowed less gas to mix with the air.
with a bbk you will need more oil then the stock oil injector will provide. there for you need to add oil to the tank.
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
9:1 gears
jdm tail lite
1982 suzuki FA50
True, which is why bakaracer upjetted to an 88.ktroy wrote:Does that not lean the fuel mixture somewhat? I always thought it allowed less gas to mix with the air.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
But mostly because the bigger bore will require more fuel. With a larger bore, you have more area at a higher rpm (assuming you upgrade the pipe), both require more oil than the stock pump.evilone wrote:True, which is why bakaracer upjetted to an 88.ktroy wrote:Does that not lean the fuel mixture somewhat? I always thought it allowed less gas to mix with the air.
bakaracer wrote:you can do that with pretty much all the stock stroke big bore kits. I was running a char mo 50mm bore with non ported case on my 96 elite s with stock carb ,stock exhaust and 9to1 gears and had that setup on my bike for over 7years with no issues at all.I just tied open the oil injector,ran motul 710 oil and about an ounce of oil per tank full. upjetted to a 88 and thats it. buried the needle on the flat no problem.you just wont get the full power of the kit but good enough.
