First spree AF16 motor swap. more photos of motor work.
Kevinstonge
Re: First spree AF16 motor swap
Trust me, I'm all for slammed rides, but graphite is right about that shock angle. But as long as your prepared for it, then I say give her *!!! Any plans for slamming the front end??
- paulpauly7
low down all good
hi graphite9. your right i'm going for normal ride.graphite9 wrote:he will see when he rides it. Its not really rideable at that angle. The smallest bump and that metal will slice that tire open. You can build a dio spree low with a good shock angle. I did this build for a guy. Not my style but he is the customer. Its 8"stretched dio, slammed and rides like stock.
P.S sweet ride.
hi kevin. graphite9 is right i'll have to got for the normal ride height.Kevinstonge wrote:Trust me, I'm all for slammed rides, but graphite is right about that shock angle. But as long as your prepared for it, then I say give her *!!! Any plans for slamming the front end??
the shock mount. it's strong.
- 20131018_002232[1].jpg (123.36 KiB) Viewed 9172 times
- 20131018_002250[1].jpg (145.91 KiB) Viewed 9172 times
- 20131018_014747[1].jpg (135.67 KiB) Viewed 9172 times
the welder is a 110v flux wire, no gas. cheap home depot.
- 20131018_015459[1].jpg (123.16 KiB) Viewed 9170 times
- 20131018_025149[1].jpg (106.33 KiB) Viewed 9170 times
that should hold.
, if not? get a bigger welder
- 20131018_025400[1].jpg (125.46 KiB) Viewed 9169 times
- 20131018_025220[1].jpg (99.21 KiB) Viewed 9169 times
I see. I think i'm going to cut the metal by the rear wheel. i'll post a photo when I cut the rear off.graphite9 wrote:he will see when he rides it. Its not really rideable at that angle. The smallest bump and that metal will slice that tire open. You can build a dio spree low with a good shock angle. I did this build for a guy. Not my style but he is the customer. Its 8"stretched dio, slammed and rides like stock.
- paulpauly7
cut it and run led lights at the rear that would look badass
I welded and reinforced the frame.
I know my welder sucks. LOL
some guys don't add any metal to the frame. they just bolt the motor right to the frame and go.
- 20131019_223329[1].jpg (140.1 KiB) Viewed 9154 times
- 20131019_223402[1].jpg (151.99 KiB) Viewed 9154 times
- 20131019_224052[1].jpg (130.53 KiB) Viewed 9154 times
this is a primer sealer.
- 20131019_232923[1].jpg (86.76 KiB) Viewed 9154 times
- 20131019_232932[1].jpg (76.86 KiB) Viewed 9154 times
- 20131019_235845[1].jpg (169.45 KiB) Viewed 9154 times
That looks a little hairy, I would do a little more support on that motor mount area, but thats me and I plan on doing 70+ on my SpreeX50.
- swimmingfree
LoveMyHonda
doing 70+ on my SpreeX50 hope to see that build!!!!!!!!!
hi graphite, the welder is a cheap flux wire type, but weld is strong. i'm not mounting to last holes. I kept them in case I reinstall my spree engine. and standgraphite9 wrote:What just happened with that motor mount welding? I hope your not mounting to the last outer set of holes.
hi lovemyhonda, I'm only going about 57MPH, you can see on my GPS phone app.LoveMyHonda wrote:That looks a little hairy, I would do a little more support on that motor mount area, but thats me and I plan on doing 70+ on my SpreeX50.
- 20131020_151640[2].jpg (121.48 KiB) Viewed 9290 times
