87 elite fuse
87 elite fuse
so i found a new problem on my 87 elite it keeps burning my fuses and i still cant find the problem
Re: 87 elite fuse
Regulators occasionally fail internally causing a current draw large enough to blow the fuse.87 elite it keeps burning my fuses and i still cant find the problem
If fuses are blowing without turning on the ignition, disconnect the rectifier/regulator as a troubleshooting step.
Re: 87 elite fuse
i disconnected it but i have no break light nor high bean now
- martynkim
Re: 87 elite fuse
That isn't your fix, it was only meant to troubleshoot the issue. If it stops blowing you have a bad rectifier.
Re: 87 elite fuse
For troubleshooting purposes, a single strand of wire can be used as a temporary fuse, you have to strip down some stranded wire and put it between some test clamps. Use a mic and do some calculations or just hook up a test piece to an ammeter directly to a battery with a known resistance in series.
If you dont understand this, keep buying fuses, much safer:)
84 Aero125 Goldie, For Sale, parts bikes too
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
Re: 87 elite fuse
sound like a good idea ill give it a shot wen i get it back from the shopClemSpree wrote:For troubleshooting purposes, a single strand of wire can be used as a temporary fuse, you have to strip down some stranded wire and put it between some test clamps. Use a mic and do some calculations or just hook up a test piece to an ammeter directly to a battery with a known resistance in series.
Re: 87 elite fuse
Comes in handy for those, "Well, I think I found something....nope" events. I usually use small jumper wires as well(to connect to the strand) and make sure I keep everything from any grounds.
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
09 Stella For Sale
86 Razz
87 YSR50
56 LD150
79 P200
