First spree AF16 motor swap. more photos of motor work.
Kevinstonge
Re: First spree AF16 motor swap
Post by Kevinstonge »
Trust me, I'm all for slammed rides, but graphite is right about that shock angle. But as long as your prepared for it, then I say give her *!!! Any plans for slamming the front end??
paulpauly7
Post by paulpauly7 »
low down all good
ped
Post by ped »
graphite9 wrote:he will see when he rides it. Its not really rideable at that angle. The smallest bump and that metal will slice that tire open. You can build a dio spree low with a good shock angle. I did this build for a guy. Not my style but he is the customer. Its 8"stretched dio, slammed and rides like stock.
hi graphite9. your right i'm going for normal ride.
P.S sweet ride.
ped
Post by ped »
Kevinstonge wrote:Trust me, I'm all for slammed rides, but graphite is right about that shock angle. But as long as your prepared for it, then I say give her *!!! Any plans for slamming the front end??
hi kevin. graphite9 is right i'll have to got for the normal ride height. :coolcruise:
ped
Post by ped »
the shock mount. it's strong. :thumbwink:
ped
Post by ped »
the welder is a 110v flux wire, no gas. cheap home depot. :roll:
ped
Post by ped »
that should hold. :smile: , if not? get a bigger welder :lol: .
ped
Post by ped »
I see. I think i'm going to cut the metal by the rear wheel. i'll post a photo when I cut the rear off. :lol:
paulpauly7
cut it and run led lights at the rear that would look badass
ped
Post by ped »
I welded and reinforced the frame. :thumbwink: I know my welder sucks. LOL
some guys don't add any metal to the frame. they just bolt the motor right to the frame and go. :nervous:
ped
Post by ped »
this is a primer sealer.
LMH
Post by LMH »
That looks a little hairy, I would do a little more support on that motor mount area, but thats me and I plan on doing 70+ on my SpreeX50.
Post by swimmingfree »
LoveMyHonda
doing 70+ on my SpreeX50 hope to see that build!!!!!!!!!
ped
Post by ped »
graphite9 wrote:What just happened with that motor mount welding? I hope your not mounting to the last outer set of holes.
hi graphite, the welder is a cheap flux wire type, but weld is strong. i'm not mounting to last holes. I kept them in case I reinstall my spree engine. and stand :smile:
ped
Post by ped »
LoveMyHonda wrote:That looks a little hairy, I would do a little more support on that motor mount area, but thats me and I plan on doing 70+ on my SpreeX50.
hi lovemyhonda, I'm only going about 57MPH, you can see on my GPS phone app. :smile: 9to1 gears. 72 polini corsa. :coolcruise:
