First spree AF16 motor swap. more photos of motor work.
Re: First spree AF16 motor swap
almost finish
- 20131028_052648[1].jpg (177.01 KiB) Viewed 9820 times
- 20131028_052809[1].jpg (197.85 KiB) Viewed 9820 times
ok spree owners, what do you think? how's it looking?
my first spree A16 motor swap. still need a pipe and carb.
- 20131028_162216[1].jpg (182.75 KiB) Viewed 9804 times
- 20131028_162253[1].jpg (186.08 KiB) Viewed 9804 times
- 20131028_162406[1].jpg (178.39 KiB) Viewed 9804 times
it's running and lights are on
- 20131028_181217[1].jpg (162.14 KiB) Viewed 9804 times
- 20131028_181240[1].jpg (176.88 KiB) Viewed 9804 times
- paulpauly7
so hows it go
Hi paul, i'm still braking in the polini 72cc headpaulpauly7 wrote:so hows it go
paul, it runs better with the stock air box. but is to big. what air filter are you using? hit me back.
can't wait to hit the WOT down the long route road.
let me put some miles and ill give you what the top speed is.
P.S do you like my bicycle kickstandped wrote:Hi paul, i'm still braking in the polini 72cc headpaulpauly7 wrote:so hows it go. you can feel the light weight off the spree
. when i hit the throttle it put a smile on my face
it is very stable for something so small.
can't wait to hit the WOT down the long route road.![]()
- paulpauly7
ive got a ct intake 24mm oko and k&n pod filter .Send me your email ill send some pics of my spreedio
Nice! I have a bicycle kick stand on my dio spree as well!
Build thread viewtopic.php?nomobile=1&f=16&t=28508
Nice man!
hi paul, I have to keep a stock carb to get the most miles per gal.paulpauly7 wrote:ive got a ct intake 24mm oko and k&n pod filter .Send me your email ill send some pics of my spreedio
I don't know, it's to cold to ride very far.
thank you, LoveMyHonda.LoveMyHonda wrote:Nice man!
I like it . its got a little kick on that motor, with that 72cc polini.
i'll post top speed when it breaks in a bit.
hi nujee, yea they work good for the price. FREEnujee wrote:Nice! I have a bicycle kick stand on my dio spree as well!
nujee do you have a photo of your spreedio?
I painted the frame, body twice, wheels, change the shock mount, rear tail light, the wire connections, longer brake cable, kickstand, grease the forks and wheel, you should know the fork bearings are lose. motor work.
I have a new seat cover , but I like the strip down look. I going to use a thin pad for seat cushing, and i'm looking for same led turn signals.
- 20131028_162253[1].jpg (186.08 KiB) Viewed 9473 times
- before
- 20131011_163845[1].jpg (200.48 KiB) Viewed 9473 times
- after
- 20131028_162216[1].jpg (182.75 KiB) Viewed 9473 times
- paulpauly7
nice work man .Now isnt a swaped spree friggen awesome to ride
hi paul, I can stop smiling
