big block 125cc elite build
- paulpauly7
Re: big block 125cc elite build
$75 sounds rich for honing a cylinder
- Goped
had to be bored 20 thou but yeah i think it was high top
- Goped
welp new news the guy said the bore wouldnt clean up well at the .5mm oversive and i had to get a custom weisco forged piston and the bore overbored 1.5mm or.060 so now it is a 56.5mm bore. the only odd thing is were i have to blend the ports back i can see the transition from the steel bore to the aluminum outer cyl, kinda odd as im used to either or on a scoot engine. but will keep you guys updated just need to find a rear wheel now and be ready to mount
