eBay gy6 150
eBay gy6 150
What is about top speed on gy6 150 long case if I throw it on a spree with the biggest wheel that will fit all stock brand new
Re: eBay gy6 150
The original motor I had on it was used and it was a gy6 150 it was about gone wen I got it with 4000 on it but I got maby 400 out of it now I'm chopping frame to make a drag mid size pocket bike with Tomis forks stretched VIP 150 Fran. That I'm chopping to crotch rocket kinda style with low seat moved to middle of frame in stef of back and low straight bar , folded sheet metal for ferrings and no electronics at all I choped up a wire harnes. It's down to cdi regulator and push button start rifle for run switch and the coil and stator plug
Re: eBay gy6 150
Graphite I know you no ur s*** about mopeds I'm building that custom gy6 150 on a home made frame pretty much I don't want any electronics at all please fill me in if you no how to wire up the cdi stator and all the nececitys
Re: eBay gy6 150
If you find that please send to me all I want it to have is the nesecitys and electric start I can't figur out if I pig tail off red that goes from cdi to regulator or whit or what
Re: eBay gy6 150
I don't know if u get wat I'm saying. I'm puting a GY6 150 on a home made frame I took the black sleeve off all the wire. I want to get rid of all the wire I can and I did I have it down to like 15 short wires. I'm making a little box right by the motor to hotels all of it I just want the coil wire sticking out and the stator plug pretty much. You are on a scooter build Topic Gy6 on spree frame , the guy building it has a pic of wat I'm talkin about but I can't follow his wiring because of pickture
Re: eBay gy6 150
(Elite E 83cc GY6 drag scooter) that's the topic it's in scooter builds
Re: eBay gy6 150
