Does anybody know what pipe this is?
mardotx3
Post by mardotx3 »
Is it comparable with a V8, Burial or PG long?
Screen shot 2013-12-14 at 11.10.53 PM.png (194.17 KiB) Viewed 19425 times
sanjuro
Re: Does anybody know what pipe this is?
Post by sanjuro »
If you're in Japan you have acess to pipes better than that.
mardotx3
Post by mardotx3 »
So what pipe do you recommend?
cruzingratiot
Post by cruzingratiot »
mardotx3 wrote:So what pipe do you recommend?
you should give more info on your build
what size motor are you planning on building stock or overbore ect
and what is your intended use race, street driving
and your budget $$$
there a lot of pipes and a lot of opinions depending on what you want to do
Donate Life
http://www.donatelife.net/
Thank You
LMH
Post by LMH »
That is a burial.
paulpauly7
Post by paulpauly7 »
sanjuro is right if your in japan you have so many pipe to choose from.
sanjuro
Post by sanjuro »
Don't think that's a Burial at all. Looks to be a knockoff.
I personally have owned two real Burial pipes, and the section near the cylinder head is usually a separate piece, and the welds are very distinct:
on my af35
before I sold it, this was for my af18-e motor:
paulpauly7
Those pipes are on yahoo auctions japan for cheap .Theres lots of scooter tuning shops around japan .If you speak japanese (im learning)you will be able to fi d parts that the guys in the USA dream of .
LMH
Post by LMH »
I remember that curly tail burial, I've only seen 2 other burials. Currently I have a burial copy from graphite that should be at my neighbors by the time I return this week. How'd you like the one on your af35? I know it won't be the same power.
sanjuro
Post by sanjuro »
The Burial on the af35 is a sport pipe. Somewhere between a full chamber and the stock Goshi ZX.
mardotx3
Post by mardotx3 »
How about the K2Tec pipe Sanjuro? Is it any good? I like PG long or Scorpion but I'd like to try the K2Tec. Let me know if it comparable to them.
Screen shot 2013-12-17 at 9.07.34 PM.png (209.57 KiB) Viewed 19335 times
sanjuro
Post by sanjuro »
That's a really mild pipe. If you're in Japan the speed limit is so low for 50cc scooters, it's almost a waste. Are you going for looks, acceleration, top speed, low noise, daily driving? All of those things kind of dictate the type of pipe you should get.
mardotx3
Post by mardotx3 »
Acceleration and speed. Not a daily drive. I like the Scorpion or PGLong. What's comparable in Japan?
sanjuro
Post by sanjuro »
If cost is no object, the Wind Jammer:
