Does anybody know what pipe this is?
Is it comparable with a V8, Burial or PG long?
- Screen shot 2013-12-14 at 11.10.53 PM.png (194.17 KiB) Viewed 19426 times
Re: Does anybody know what pipe this is?
If you're in Japan you have acess to pipes better than that.
So what pipe do you recommend?
- cruzingratiot
you should give more info on your buildmardotx3 wrote:So what pipe do you recommend?
what size motor are you planning on building stock or overbore ect
and what is your intended use race, street driving
and your budget $$$
there a lot of pipes and a lot of opinions depending on what you want to do
Donate Life
http://www.donatelife.net/
Thank You
Thank You
That is a burial.
- paulpauly7
sanjuro is right if your in japan you have so many pipe to choose from.
Don't think that's a Burial at all. Looks to be a knockoff.
I personally have owned two real Burial pipes, and the section near the cylinder head is usually a separate piece, and the welds are very distinct:
on my af35
before I sold it, this was for my af18-e motor:
on my af35
- paulpauly7
Those pipes are on yahoo auctions japan for cheap .Theres lots of scooter tuning shops around japan .If you speak japanese (im learning)you will be able to fi d parts that the guys in the USA dream of .
I remember that curly tail burial, I've only seen 2 other burials. Currently I have a burial copy from graphite that should be at my neighbors by the time I return this week. How'd you like the one on your af35? I know it won't be the same power.
The Burial on the af35 is a sport pipe. Somewhere between a full chamber and the stock Goshi ZX.
How about the K2Tec pipe Sanjuro? Is it any good? I like PG long or Scorpion but I'd like to try the K2Tec. Let me know if it comparable to them.
- Screen shot 2013-12-17 at 9.07.34 PM.png (209.57 KiB) Viewed 19336 times
That's a really mild pipe. If you're in Japan the speed limit is so low for 50cc scooters, it's almost a waste. Are you going for looks, acceleration, top speed, low noise, daily driving? All of those things kind of dictate the type of pipe you should get.
Acceleration and speed. Not a daily drive. I like the Scorpion or PGLong. What's comparable in Japan?
If cost is no object, the Wind Jammer:
