SA50 to SB50 motor swap, can I keep the rear wheel assembly?
starhunter
Post by starhunter »
I'll be doing an engine swap from sb50 to sa50 sometime next week and I've been doing more research while the engine is on the way. Originally I thought I would only have to mess with the mount and spring, but does the rear wheel assembly change?
I'm just getting the engine with muffler and rear spring. If needed I can also pick up the rear wheel as well. Any info would help a bunch.
thanks!
darat
Post by darat »
i think it is a direct bolt up.
No, the Spree wheel is different from the Elite wheel, to my knowledge. Try to pick up one with the wheel.
MySpree
Post by MySpree »
well, ill cheack in my garage tonight, i know that aero rims fit on, but they are alot smaller., if u u run a spree wheel on it, dude its gonna be like u slamed the ped, itle be a couple inches shorter.
