First spree AF16 motor swap. more photos of motor work.
Re: First spree AF16 motor swap. more photos of motor work.
Great photos. Looks like a VW gasket. I have bought several to keep on hand. I was abe to get them for about .47 cents each through an auto parts store.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
50mm BBK (tai)
V-8 pipe
thank you deuce. better photos of port.
- 20131224_021106[1].jpg (144.43 KiB) Viewed 10349 times
- 20131224_021143[1].jpg (143.53 KiB) Viewed 10349 times
the plug holder. I got the idea from the forum. thank you whom ever it was. Very nice people in this forum.
- 20131224_034223[1].jpg (168.07 KiB) Viewed 10349 times
- 20131224_034332[1].jpg (121.41 KiB) Viewed 10349 times
- 20131224_034615[1].jpg (159.16 KiB) Viewed 10349 times
- swimmingfree
you may need some goo behind that quarter....
hi swim. there a oil plug behind the quarter. almost done with the carb & pipe install
- 20131224_054041[2].jpg (172.02 KiB) Viewed 10352 times
its tight I have blue Loctite on threads.ped wrote:the plug holder. I got the idea from the forum.
- swimmingfree
if air leeks by the quarter it will run lean and we all no what that means....
A hole on the piston? oh! your saying the o-ring is not enough. got it . thanks will do more sealing.swimmingfree wrote:if air leeks by the quarter it will run lean and we all no what that means....
- swimmingfree
better to be sure that all is leak free...
ps
you have a good read and nice photo as welll
ps
thank you again swimmingfree. just like this fourm helped me , maybe it will help someone elseswimmingfree wrote:better to be sure that all is leak free...
ps
thanks graphite. I not finish with setup. did you noticed how close the pipe is to the fan shroud? looks like I will have to order some exhaust wrap for the pipe.graphite9 wrote:Ped, I have the correct carb cable for your oko. Your going to have issues with how you have it set up now. I doubt your slide will even close with that cable. It will probably start at 1/3-1/2 throttle
my new premix oil baby bottle. holds 9 OZ. $1 at dollar store
- 20131224_201658[1].jpg (79.25 KiB) Viewed 10317 times
I see you need to take your scooter other places too
yes the cable is off the spreedio. just waiting on CHT gauge. to install together.
I did the pilot jet trick. some one on the forum showed how. I can't remember who. thanks for the tip.
I cut away a little on the bowl. so the pilot jet will come out, without taking the bowl out.
for the person who posted that trick.
Thanks for the tip cruzingratiot . you have a very nice detail build.
- I file down the screwdriver to fit in the small jet.
- 20131228_183531[1].jpg (157.73 KiB) Viewed 10277 times
- 20131228_183155[1].jpg (150.61 KiB) Viewed 10277 times
- very little was cut out.
- 20131228_183941[1].jpg (147.36 KiB) Viewed 10277 times
