First spree AF16 motor swap. more photos of motor work.
ped
Re: First spree AF16 motor swap. more photos of motor work.
Post by ped »
I painted the CT manifold black. going for the sleeper look. :naughty:
ped
Post by ped »
I plasti dip the carb. it's the rubber spray in a can. you can peel it off with a toothpick.
ped
Post by ped »
the CHT gauge is in. don't want to burn up the piston.
ped
Post by ped »
hi forum. how's it look? :thumbwink: I am getting sleepy :naughty:
ped
Post by ped »
photos are with camera phone.
ped
Post by ped »
I installed the PG short pipe. what a pain in the a** that was. had to use a bunch of washers to make it fit.
WOW! look at all that trash in the garage. :shock: lol.
paulpauly7
Post by paulpauly7 »
nice
ped
Post by ped »
the pipe looks a little low? :nerd:
ped
Post by ped »
I wonder if it will hit a speed bump? :confused:
ped
Post by ped »
paulpauly7 wrote:nice
thank you paul. it was a lot of work. but I'm happy. :smile: :coolcruise:
I don't understand why my neighbors do not like my new pipe :confused: . wait till I get the Arrow pipe they are going to love me :lol: .
ped
Post by ped »
hi forum. I've been riding and noticed not a lot of top end power. so I did a compression test and I have 80 psi. that is to low.
Update. the compression tester was no good. lack of power was the carb jets and tuning.
ped
Post by ped »
I did a squish clearance test and came up with 0.95mm. I should be around 0.6-0.8mm.
ped
Post by ped »
I think i found the problem for the low psi on head. I use rtv silicone to seal and, cover some of the scratches on the cases. the silicone may have lifted the head a few mm.
Update: the compression tester was no good. a very thin layer of silicone on base gasket is ok for sealing.
ped
Post by ped »
graphite9 wrote:Yeah I wouldn't have used that on the case. I sometimes use a super thin layer of hondabond. did you find a leak there?
hi graphite. I have to get a pressure tester to check the gaskets. I don't see or hear any leaks. Everything is dry. :confused:
thanks. all help is appreciated.
ped
Post by ped »
hi graphite. the problem was the cylinder head compression tester. craftsman tester was not accurate. I rented one from autozone $40. the head compression PSI is now about 115+psi. that's good.
