First spree AF16 motor swap. more photos of motor work.
Re: First spree AF16 motor swap. more photos of motor work.
I painted the CT manifold black. going for the sleeper look.
- 20131228_174603[1].jpg (135.42 KiB) Viewed 10343 times
- 20131228_174632[1].jpg (143.5 KiB) Viewed 10343 times
I plasti dip the carb. it's the rubber spray in a can. you can peel it off with a toothpick.
- 20131228_202319[1].jpg (149.79 KiB) Viewed 10343 times
- 20131228_202441[1].jpg (161.25 KiB) Viewed 10343 times
- 20131228_202536[1].jpg (165.04 KiB) Viewed 10343 times
the CHT gauge is in. don't want to burn up the piston.
- 20131229_024804[1].jpg (149.56 KiB) Viewed 10341 times
- 20131228_214107[1].jpg (180.9 KiB) Viewed 10343 times
hi forum. how's it look?
I am getting sleepy
- 20131229_024319[1].jpg (167.03 KiB) Viewed 10341 times
photos are with camera phone.
- 20131229_024745[1].jpg (163.13 KiB) Viewed 10341 times
- 20131229_024707[1].jpg (163.89 KiB) Viewed 10341 times
I installed the PG short pipe. what a pain in the a** that was. had to use a bunch of washers to make it fit.
WOW! look at all that trash in the garage.
lol.
- paulpauly7
nice
the pipe looks a little low?
I wonder if it will hit a speed bump?
thank you paul. it was a lot of work. but I'm happy.paulpauly7 wrote:nice
I don't understand why my neighbors do not like my new pipe
hi forum. I've been riding and noticed not a lot of top end power. so I did a compression test and I have 80 psi. that is to low.
Update. the compression tester was no good. lack of power was the carb jets and tuning.
- 20140104_025017[1].jpg (165.64 KiB) Viewed 10822 times
I did a squish clearance test and came up with 0.95mm. I should be around 0.6-0.8mm.
- 20140104_023317[1].jpg (148.38 KiB) Viewed 10821 times
- 20140104_023701[1].jpg (131.59 KiB) Viewed 10821 times
I think i found the problem for the low psi on head. I use rtv silicone to seal and, cover some of the scratches on the cases. the silicone may have lifted the head a few mm.
Update: the compression tester was no good. a very thin layer of silicone on base gasket is ok for sealing.
- 20140104_023742[1].jpg (127.03 KiB) Viewed 10821 times
- 20140104_025626[1].jpg (158.84 KiB) Viewed 10821 times
hi graphite. I have to get a pressure tester to check the gaskets. I don't see or hear any leaks. Everything is dry.graphite9 wrote:Yeah I wouldn't have used that on the case. I sometimes use a super thin layer of hondabond. did you find a leak there?
thanks. all help is appreciated.
hi graphite. the problem was the cylinder head compression tester. craftsman tester was not accurate. I rented one from autozone $40. the head compression PSI is now about 115+psi. that's good.
- 20140118_003808[1].jpg (168.14 KiB) Viewed 10730 times
