Ok. I'm happy to report that we have a runner now but it wasn't the ground or the points.
Luckily for me my local dealer had the 1 and only flywheel puller in town and it was an exact fit for my application.
Before I got started pulling the flywheel I made sure there was a good ground, a new coil, new spark plugs and a new cap. Keyword here is NEW.
Alas I still didn't have spark, I did my best to clean the points through the opening but it sucked pretty bad and still no spark. So.. yeah flywheel puller to the rescue.
Here's the magneto, points are good, windings are in good order.
I wonder how those magnets look? BAM - looks like this could use some cleaning - took out a scuff pad and went to work.
After I got the magneto reassembled went to check for spark and got it.
Woot Woot - so here's a video of technically the 2nd start - the first one had alot of smoke in the garage to the point where the wife was yelling at me.
Purrs like a 2 smoke -
Boy just when you think you're done cleaning... I had to take off the headlight to service the speedo cable as it had a terrible whine and was dry as a bone.
I found this inside -
Got her cleaned up and dressed again with body parts and took her out for a photoshoot so here she is in the New Mexico sun.
1 More video to cap off the project -
[YOUTUBE]<iframe width="560" height="315" src="//
www.youtube.com/embed/w5IevM2FU9o?rel=0" frameborder="0" allowfullscreen></iframe>[/YOUTUBE]
If that embed code didn't work here's the link:
Suzuki RV90 - YouTube
I didn't do any bodywork as you can tell and I'm not sure if I will. I just wanted to bring it back to life and clean it up. I'm sure my kids will ride and wreck it before too long so maybe then I can think about the Lifan 125cc or the new paint job.
Thanks for reading and good luck out there.
