Million Dollar Scooter Build
Limp1144
Re: Million Dollar Scooter Build
Post by Limp1144 »
2x polini corsa bores ordered. 500.00
Parts total $$$$$$1327.43$$$$$$ :(
refl3x
Post by refl3x »
yikes I guess i was lucky i got a 98 SR for $12.50
Limp1144
Post by Limp1144 »
Who even came up with that number 12.50 hahahaha.
Bought two sets of wheel inserts 75.00
refl3x
Post by refl3x »
it was two scooters for $25 one was crap so i stripped it to the frame to make a "drag" scooter the other only had around 500 miles and is pretty clean. maybe i missed it but why are you buying two of everything?
Limp1144
Post by Limp1144 »
GO FAST PARTS
Thanks Taz
Glow in the dark throttle cables, 24mm carbs, 9:1 gears, CT intaaaaakkkeesss
This is looking smooth.
Limp1144
Post by Limp1144 »
First person ever to use 3 variators on 1 scooter
DDX
SEF Ramp plate
Limp1144
Post by Limp1144 »
This looks like it will take me to 60mph.
Limp1144
Post by Limp1144 »
Tuning Question
I got an elite I fired up. When I turn the air screw out 1 turn from all the way in it revs up. Shouldn't the air screw be turned out 2.5 times. Does this mean I have too big of a pilot jet. I think I put a 48 pilot in a 26mm oko
LMH
Post by LMH »
Too small of a pilot.
Limp1144
Post by Limp1144 »
Any know where the wiring diagram is for the jdm taillight. I got it all ready to go back together but need the wiring for the tail light thanks.
Roger that LoveMyHonda. think I can get away with a 42 pilot 125 main on a 24mm carb
Limp1144
Post by Limp1144 »
Also does anyone have any pics to dremel out the carb bowl so I can swap the pilot too. thanks
ped
Post by ped »
Limp1144 wrote:Also does anyone have any pics to dremel out the carb bowl so I can swap the pilot too. thanks
Hi limp. remove very little at a time until the pilot come out. try not to touch the drain bolt seat. it may leak. take your time. If you drink too much coffee, try at your own risk. :nervous: good luck.
ped
Post by ped »
Limp1144 wrote:Any know where the wiring diagram is for the jdm taillight. I got it all ready to go back together but need the wiring for the tail light thanks.
Hi limp. I don't have one but follow the colors on the wires. use your other scooter as a guide.
Limp1144
Post by Limp1144 »
Look what came in the mail today.
Two Polini Corsa bores.
Wheeeeel Insertssss
I might sell these wheel inserts if anyone wants them two sets for 80 plus shipping.
KingJeff801
Post by KingJeff801 »
here you go
http://www.hondaspree.net/phpBB3/viewto ... ght#p80497
2001 Elite S
72cc Corsa
24mm OKO
Scorpion Pipe
Pic and Vid post
Gun Post
Wrong Side Kings 4 Life
