Spree bbk tuning help
Provost33
Re: Spree bbk tuning help
Post by Provost33 »
Where can I find taller gears for a 85 spree?
paulpauly7
Post by paulpauly7 »
from taz
Provost33
Post by Provost33 »
Al of them on eBay are OEM that I see
paulpauly7
I actually have a set of taz tall gears for a spree only problem is i live in New Zealand and shipping is about $60 usd
Provost33
Post by Provost33 »
Carb came in today... its actually 24mm not 21. Is it still going to work? It mounts fine but I'm guessing I'll have to run a smaller jet
paulpauly7
yes but will be hard to tune with a stock pipe .You need the MLM pipe
Provost33
Post by Provost33 »
OK thanks.. well I tried it with the stock pipe just for the heck of it.. I mixed 50:1 oil plus the pump.. it started up and actually sounded pretty good.. I've got a 90 main jet. And a hole in the exhaust... the only problem is after about 1 min I noticed the oil was only about half way up the tube to the carb.. what could be causing the lack of pressure? Or is it normal to move that slow and I need to manually fill the tube first
Provost33
Post by Provost33 »
Provost33
Post by Provost33 »
Provost33
Post by Provost33 »
paulpauly7
if i was you id remove the oil pump and go full premix if not then put your petcock vacume hose to that barb on the carb where your oil line goes and oil line to the manifold .Also the pump is a very slow drip so it will take a while to fill the line completly befor it gets to the carb .
I recommend you navigate over to the Manuals section of the Forum and have a look in the engine section for the procedure to prime the lines to the pump. Your engine has been running on the Premixed oil in the tank ONLY so far. While most would think that a bit thin for break-in, it seems 50:1 is enough oil for survival this far. I predict it won't sound so good and run as clean when the pump oil finally reaches the intake.
Nice, clean work on the conversion, by the way.
PorterGuy85
Post by PorterGuy85 »
I wanna see what these starcross tires are going to look like on this !!!!
PorterGuy85
I wanna see what these starcross tires will look like when mounted!!! :-)
patthesoundguy
Post by patthesoundguy »
Provost33 wrote:OK thanks.. well I tried it with the stock pipe just for the heck of it.. I mixed 50:1 oil plus the pump.. it started up and actually sounded pretty good.. I've got a 90 main jet. And a hole in the exhaust... the only problem is after about 1 min I noticed the oil was only about half way up the tube to the carb.. what could be causing the lack of pressure? Or is it normal to move that slow and I need to manually fill the tube first
Yeah need the mlm pipe. It rips. I'd almost think the stock pipe would be better with no extra holes in it. But thats just me. There is something to the design of the spree exhaust. I think if you want more out of it you would be better off enlarging the internals or possibly just the stinger just slightly but keeping everything the same lengths. Back pressure is a slippery slope, too much sucks, too little sucks hard to get it on the money. Hard to beat a real tuned pipe :-) also your slow moving oil in the line is normal. There is a only a small amount of oil that comes out if that line. The pump provides the oil pressure, back pressure has no effect on the oil pump. I prime my oil lines with my oil can of the same two stroke oil that I use in the oil tank. Just fill the oil line from the pump to the intake so you have as little air as you can get. Its easy. Sometimes I fill the line and install it and top the end up that goes to the intake.
Sent from my Nexus 7 using Tapatalk 4 Beta
