Hi forum.
I was changing my belt on my piaggio and decided to do a variator size comparison.
I have a stock piaggio 500 ,and a stock Elite 50 variator. take a look at the size difference.
small photo size due too camera phone.
Piaggio 500 vs Elite 50 variator size comparison
- notice the pulley in the center
- 20140420_003203[1].jpg (181.05 KiB) Viewed 13036 times
- 20140420_040638[1].jpg (158.31 KiB) Viewed 13036 times
- can you see the rollers
- 20140420_040903[2].jpg (165.49 KiB) Viewed 13036 times
Re: Piaggio 500 vs Elite 50 variator size comparison
more photos
- 20140420_041956[1].jpg (136.25 KiB) Viewed 13034 times
more photos
- 20140420_042425[1].jpg (172.26 KiB) Viewed 13034 times
- 20140420_042758[1].jpg (167.69 KiB) Viewed 13034 times
- torque 2 specs
- 20140420_050111[1].jpg (180.4 KiB) Viewed 13034 times
I use powder graphite on the new rollers.
- 20140420_032413[1].jpg (174.33 KiB) Viewed 13029 times
- have to clean the case.
- 20140420_032436[1].jpg (154.54 KiB) Viewed 13029 times
Thanks ped.
Wear marks on your Piaggio show min dia is about our scooters max:lol: Calculation of belt speed shows almost 90mph at 5500rpm. Our 50cc/3" pulley needs a bit over 10k to hit 90.
Trans has forced air cooling, interesting they exhaust the air out the front, rather than forcing all air past clutch and exhausting out the back.
- Cooling_air_path.jpg (53.11 KiB) Viewed 12998 times
hi mousewheels.
the cover has a vent in the rear. what's interesting is that it has a filter in the front ,and the center. but no filter out the exhaust side. you can see the rear pulley. I guess the air blows all the dust out the rear. no filter needed in the rear with the fan blowing filtered air through.
- 20140428_032411[1].jpg (124.62 KiB) Viewed 12988 times
- 20140428_032311[1].jpg (123.65 KiB) Viewed 12988 times
Hi mousewheels.
the 500 top speed is always 100+ on flat road. I not sure about the RPM's.
- 20140428_040518[1].jpg (146.3 KiB) Viewed 12988 times
Hi mousewheels.
the japan made Yamaha morphous 250cc has the same filtered air system. with no air filter on the outlet.
We may all use a air filter system on the elite's? but without a fan, it will have to be a ram air system.
- 20140428_042805[1].jpg (161.25 KiB) Viewed 12987 times
- 20140428_042709[1].jpg (144.9 KiB) Viewed 12987 times
Hi Mousewheels.mousewheels wrote:Thanks 'ped for corrections
Your observations and all opinions are always welcome.
thanks.
