Fuel Ratio for 86 Spree
chad.sellers
Hey guys I have an 86 Spree with a 48mm big bore kit, gear upgrade, and an MLM pipe. I just purchase an OKO 21mm carburetor kit and am wondering how much performance I'm going to gain from this and what the premix ratio should be. And how do you disable the oil injector?
- paulpauly7
Re: Fuel Ratio for 86 Spree
grind the teeth off the shaft then reinstall dissconnect the oil lines and plug them up.Run premix 32:1 and you will be sweet
chad.sellers
Sweet man thanks
