Polyurethane Motor Bushings Upgrade
da808nanospeed
Post by da808nanospeed »
Most of our Dio Motor's Bushings are bad due to age of the rubber inside the bushing, So I decide to upgrade to Polyurethane, Also It will stiffen up the frame and hopefully will last longer.
2003 Yamaha R1 998cc SOLD
1997 Honda Elite S 72cc SOLD
2007 SYM DD50 72CC X2
Goped sport 29cc
LMH
Re: Polyurethane Motor Bushings Upgrade
Post by LMH »
What're they off of or from where? Nice upgrade
da808nanospeed
I homemade it, is actually energy suspension sway bar bushings, I took the boss from the old rubber bushings, grind off the rubber then press it into the Polyurethane bushing.
Goped sport 29cc
deuce217
Post by deuce217 »
Good stuff. I wish I did not give away my bag of poly bushings a few months ago. I had a complete set for a 99 civic but sold the car and did not think of anything creative with them so I passed them along.
50mm BBK (tai)
V-8 pipe
36 grams in Prodigy variator
65mph GPS (on the freeway)
ped
Post by ped »
Hi da808. I agree with graphite. if the bushing pops out please be careful. do a lot of test runs and checks.
I do love the idea.
da808nanospeed
Thanks for the advises, I will keep an eye on it.
Goped sport 29cc
ped
Post by ped »
hi da808. please keep us posted on how they hold up.
I will soon need bushings for my elite and like to try your upgrade. thanks.
veedubh20
Post by veedubh20 »
Lol. Bearing bushings has all minarelli jogs
ped
Post by ped »
Hi da808. how the Polyurethane bushing working out?
Anyone think Polyurethane bushings will work on the shocks? :nerd:
maddog
Post by maddog »
good luck getting off the old ones :smile:
ped
Post by ped »
graphite9 wrote:New oem bushings are $8ea. There is no reason to go to a poly bushing. All your doing it transferring more vibration. You are installing a custom made bushing into a location it's not intended for. Stick with oem. Honda had it right the first time :)
Hi G9. I was thinking of using it on my shock.
I'm sure the motor will vibrate with the poly bushings. that's not good. I wont do it. :coolcruise:
Mystic
Post by Mystic »
Yea don't try to knock them out with a hammer lol I learned that the hard way at least it was an afo5 I busted. Side note u can use a large thick washer on the outside of each bush as a protective from the bushings sliding out
LMH
Post by LMH »
They're extremely easy to press out and back in. Extremely. Right tool for the job helps a ton.
veedubh20
Post by veedubh20 »
motor ball bearings mount. mo betta! :rock:
